Question about Nokia 6120
Nokia 6120 only works in loudspeaker mode
Ever since I paired my 6120 with Blueant ST3 the phone will not work other than in loudspeaker mode when not connected to the Blueant. I disconnect properly from the Blueant and the phone says it's disconnected. I've tried completely resetting the phone to no avail. Very frustrating as it is now impossible to have a private conversation on my phone. Nokia no help.
It wont pair it keeps saying (make sure blueant st3 is turned on in range and is ready to pair
What you need to do is to put the device into pair mode before hand, to do this with the device off hold down the green button until you hear a language loop. When you hear the language of your choice let go of the green button and press it once right away. When you hear a message about your phones bluetooth menu, go to your bluetooth menu and search for devices. Select the ST3 and enter the pin code 0000 if prompted. If at that point it is not accepting that code, do a hard reset on your phone. To do this remove the battery from your cell while it is powered on(if u have an Iphone do a full power cycle) when your phones back up search again enter the pin and it should work.
Rylan
Dec 04, 2010 | Blueant Supertooth 3
Im trying to pair my iphone with my blueant but it keeps saying (make sure blueant st3 is turned on in range and ready to pair)
First off the device you are referring to is a ST3 and not a Z9. What you need to do is put the device into pair mode prior to searching in your iphones bluetooth menu, to do this with the device off hold down the green button until you hear a language loop. When you hear the language of your choice let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go to your Iphones bluetooth menu and select the ST3 and it should work.
Regards,
Rylan
Dec 04, 2010 | Blueant Z9 Wireless Headset
Having difficulty pairing BlueAnt ST3 with Blackberry Curve. Blackberry recognizes BlueAnt but does not accept code of 0000. Says "connection failed"
Make sure the device is in pair mode, to put it into pair mode hold the green button down until you hear a language loop (with the device off). When you hear the language of your choice let go of the green button and press it once right away. When you hear that go to your phones bluetooth menu and enter pin code 000 when prompted. If this does not work do a hardreset on your phone by removing the battery while it is powered on, when it is back up research and repair and it should work.
Rylan
Oct 14, 2010 | Blueant Supertooth 3
Having trouble pairing phone with Blue Ant ST3
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol " and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Apr 17, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Not Connecting to phone
try this site ... its the blueant homepage .. will have a solution there for you ....http://www.blueant.com.au/index.php
Apr 07, 2010 | Blueant Supertooth Light Bluetooth Speaker...
I lost the passcode to my bluetooth i tried 0000 9999 and all others no pairing its a bluetooth 10799 and it goes in ciggerrette lighter and u can talk out loud please help dont want a ticket lol
How to connect or pair a Blueant Bluetooth handfree.
1. Switch off the Blueant:
i.e. push the microphone inside the Blueant.
2a. Press and hold the GREEN telephone symbol (or Accept) pushbutton
On the Blueant flat face for 8 seconds. (this makes unit go into “pairing” mode)
2b. at the same time switch Power On to the Blueant by pushing out
the microphone on the side of the Blueant.
3.The Bluetooth Indicator will turn a blinking red/blue,
when you see this, release the Accept Button .
The Blueant is now in “pairing” mode.
4. Get you mobile in Bluetooth search mode to pair with a new device.
5. The Blueant will request your mobile device for a password.
6. Enter the password= 0000 , the devices now will be paired.
7. Set the Blueant as a trusted/authorized device, if this is option in your phone.
Mar 18, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Cannot pair blueant ST3 wih Nokia 6300
Reste the ST3 and then pairi again. It worked for me. Check this link:
http://www.myblueant.com/knowledgebase/reset/st3.php
Deven
Dec 25, 2009 | Blueant Blue Ant 091193 Supertooth II...
Blue Ant ST3 will not recognize 0000 passcode.
  2. Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
Jun 11, 2009 | Blueant Blue Ant 091193 Supertooth II...
The phone won't pair up with the blueant st3
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
May 27, 2009 | Nokia N95 Cellular Phone
Can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
  1. Press+Hold the Volume Up button and then also press the green button to reset the unit.
  2. After completing the above reset, turn the ST3 OFF again and wait at least 10 seconds.
  3. Turn unit back ON and select language when prompted.
  4. Follow the voice prompts and pair the ST3 with your blackberry as normal.
  5. After pairing has completed you will hear the ST3 announce “loading phonebook – please wait”.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
May 04, 2009 | Blueant Supertooth Light Bluetooth Speaker...
Nokia 6120 Logo
310 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
