Question about Optimus DV-5040 Camcorder
It doesnt power on via batteries, only thru usb cable
  • 35 Answers
Would need to know more info, but you can find support HERE.
Posted on Jul 05, 2010
My rino 655t wont take a charge
That unit has a special charger and harness.
Very similar to the Motorola
The Rino 650 and 655t includes a rechargeable lithium-ion battery. If the battery is not charging, ensure the battery is secure and the device is connected via the included A/C charger. The battery will not charge when connected via USB cable.
May 02, 2014 | Garmin Rino 655T Topo Gps 2-Way Radio
Will the Samsung UE27D5000NW LED TV play video from external hard drive?
"Wondering if an external hard drive will draw too much power/amps thru the TV's USB."
Yes, it probably would, so you are better off using a self-powered (one that you plug in to a wall outlet) drive.
And even if you got it running, it might crash halfway through a movie or something. But, for sheets & giggles, if you have all of the data that is on the 2.5" backed up somewhere else, give the 2.5" a try.
Good luck.
Jan 17, 2018 | Microsoft Xbox Computers & Internet
How do I recharge the battery on my Garmin Nuvi 255WT? I would also like to know how to update my Garmin?
Recharging the battery is done by connecting the nuvi to a vehicle power cable in the car through the vehicle power accessory outlet or cigarette lighter.
The unit can also be charged via a powered USB port off your computer via the USB power/data cable or an AC power adapter through the USB power/data cable.
Aug 15, 2011 | Garmin nuvi 255W GPS Receiver
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
V3i..battery problem -------------------------------------------------------------------------------- i notice that when i charge my v3i with the charger, it kept saying battery charging, it never says...
What you are describing is that there is an issue with the USB charging port on your V3i. Different pins are used when charging via the wall as opposed to via a USB computer port. It really is quite common with the V3i, you can search on the internet to get your port repaired. If you cannot find anyone, feel free to ontact me, outlet3g in the repair directory.
Good luck!!
Mar 16, 2010 | Motorola Mobility RAZR V3
Can you trickle charge the Olympus FE-20 via the usb cable?
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Jul 02, 2009 | Olympus FE-20 Digital Camera
Run wd1600 via ide-usb problems
Just replace the case the drive is in. You can get them from stores that sell computer parts like Fry's Electronics. There are many online sources too.
Feb 08, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
My iphone doesnt charge
Hi there!
There have been some reports of iPhone chargers going bad prematurely.  The test:
  1. Connect your iPhone to your computer via the USB cable.  Does it make a little beeping noise when you connect it, and then charge up?  If so, the issue is not with your iPhone or USB cable.
  2. Next, using that same USB cable, connect it to your iPhone charger.  Do you get the same connection noise and then does it charge up?  If not, the issue is probably with the charger.
Assuming you have a faulty charger, you are still well within your 1 year warranty from Apple.  Visit an Apple store (www.apple.com/retail) Genius Bar (make your reservation online before you go, to avoid waiting around), explain the issue and how you tested it out, and they will almost certainly replace the charger for you at no cost.
Oct 11, 2007 | Apple iPhone Smartphone
Optimus DV-5040 Camcorder Logo
51 people viewed this question
Top Optimus Video Cameras Experts
Are you an Optimus Video Camera Expert? Answer questions, earn points and help others
