Question about Agere All 56K Modems: 56K V.92 Lucent/ Chipset W/Voice Software Modem (MODOE5605)
Hi, to every one. I need to disable a dial tone from my laptop modem to make a data call to plac from omron. When i call from local because the sound is one tone, it dial but when i call from standard phone line, it wont works, any help pls. e-mail:strek_11705@yahoo.com
WELL I SOLVED THEE PROBLEM BY INSERTING A "x3"AT COMMAND IN THE MODEM ADVANCED SETTINGS, AND I MADE A CALL FROM STANDARD PHONE LINE.
THE IDEA WAS THAT I MAKE A BLIND CALL, TO PLC VIA GSM MODEM. THE ATX3 COMMAND MAKE BUSY IF THE LINE IS BUSY OR BLIND CALL IF LINE IS FREE.
WELL THAT'S MY SOLUTIONS,
Posted on Nov 20, 2009
NO dial tone
try to disable the wait for dial tone from menu
Jan 14, 2014 | HP J3680 Officejet All In One Printer
I have a hp compaq nx7400 laptop with an agere systems hda modem.i have a dial tone and when i try to connect to the internet the modem sounds like it is dialing but the dial tone never goes away.is the...
The Agere systems HDA modem is a 56kbps modem typically found on laptops. View it in device manager.
Start->Control Panel->System->Device Manager->Modems
Should be listed there. See if there is an exclamation mark next to it.
Not very expensive or difficult to replace
Aug 14, 2010 | HP Compaq Business Notebook nx7400
No 56k modem dial tone
DOWNLOAD NEW DRIVER FOE THE MODEM
May 15, 2009 | Acer Aspire 1400XV PC Notebook
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Modem problem
Disconnect the phone line from the modem and connect a normal phone to this phone line. Lift the handset and check it you have a dial tone and see if you can dial out.
If you don't get a dial tone then there is a fault with the phone line and it needs to be repaired before you can use your modem.
Apr 14, 2009 | Dell Latitude C640 Notebook
How do get a dial tone when using the data fax modem?
try bypassing their modem and see if you get a dial tone,,,if you do then you know thats where the problem is
Feb 26, 2009 | Computers & Internet
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Thanks, I'll call my old ISP!
Your ISP's proprietary software should detect whether your modem is getting dial tone or not, so that's how I would check the modem. Another way to test the modems connectivity would be to connect an active phone line to the in port and a landline phone to the out port and see if the phone gets dial tone?
I don't think you need to worry about disabling your network connections as there should be no conflict especially since you have no network cable attached (your ethernet/networking card will sense a connection or not).
Keep me posted.
Apr 04, 2008 | Computers & Internet
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Agere All 56K Modems: 56K V.92 Lucent/ Chipset W/Voice Software Modem (MODOE5605) Logo
114 people viewed this question
Top Agere Computers & Internet Experts
David Payne
David Payne
Are you an Agere Computer and Internet Expert? Answer questions, earn points and help others
