Question about HP Computers & Internet
My pioneer dvdrw dr-td08hb ATA was working really good, but then it stoped, now won´t even read anything and on control panel it says there´s a problem loading the controler, alredy uninstalled the controler, reboot the laptop, reinstalled the driver and nothing seems to b working till now, any advice?
  • isa83l Nov 19, 2009
    Thank you!! great help, after your advice the burner started working just fine! cool knowledge, and, if I may... could you tell me why does this happens?
    Thanks again!
  • Antony Jul 14, 2012
    OK, I'm having the same problem. I removed the UpperFilters and LowerFilters registry entry still having the same issue. I'm on Windows 7, any suggesstions?
    Novelist:
  • 142 Answers
  1. Click Start , and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Microsoft Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. G
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Posted on Nov 19, 2009
Testimonial: "Great Advice and Knowledge, solved my problem in less than 5 mins!"
  • Varghese Joseph
    Varghese Joseph Nov 22, 2009
    Plessure is all mine isa83l, Thank you.
My pioneer dvdrw dr-td08hb ata in my HP pavillion is not burning anything, I try changing the blank cd and dvds brand and also empty out most of my hard drive, try uninstal and reinstal it again and still...
If your not a PC guru then try removing DVD from device manager and reboot
if your a geek try editing your registry and remove the upper and lower filters from this HIVE HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Aug 25, 2010 | Pioneer DVR 108 Dual format 16X DVDRW...
My DVDRW DR-TD08HB ATA Device is uninstalled i need to install it but cann't do it
Go into your device manager. (Right click my computer, properties.device mgr. hardware) Find the device and enable it.
Sep 21, 2009 | HP Pavilion dv4000 Notebook
Pioneer DVDRW DR-KW08HB ATA Device driver issues
To me that sounds like something got corrupted with Windows, if you have a restore CD, or know how to reinstall your OS I would recommend that, AFTER you back up your files though as you will lose anything you had saved on there. But that could fix it, or it could be the drive is bad also.
Sep 09, 2009 | HP Computers & Internet
Pioneer DVDRW DR-KD08HB not working on HP Pavilion Solved the problem once from fixya and now the problem returned. Anyone??
You should really give more detail on the issue for people to solve the problem quicker. If you can't see the dirve on your drive list but it show up under device manager and getting error 39 you can try the following link.
http://msbin.com/kb/entry/53/
Sep 08, 2009 | Computers & Internet
Disc Drive won't read after upgrade to Vista Ultimate
I had a disc Drive that wouldn't work for a while. There are a few things that could be wrong. The first thing I would try is to make sure it's pluged in all the way to both the Motherboard and the Disc Drive. Maybe it wasn't secure in there and when you bumped you computer just a little bit, it got unpluged. The wire connecting the Disc Drive to the Motherboard is probably your thinkest wire, can't miss it.
this next thing I would try is to delete the driver for your Disc Drive and then restart your computer. It should detect it automatically and have it running correctly.
If all else fails, go to Google. Type in the name of your Driver and search for an install that is supported on your operating system.
Jul 07, 2009 | Acer (4432A-002) CD-RW Burner
My PIONEER DVDRW DVR-K15 ATA Device read cd no DVD
have you had any virus infections? I would download malware bytes and rootkit revealer to see if you have any viruses or rootkits you should email me at cringer.smith@gmail.com
and you might have a rootkit that is causing issues with the dvd read/write. otherwise a failing device.
you could also burn puppylinux on a cd, run it and see if you can pop in a dvd and see if it reads the media. if so you are looking at a windows software file or virus issue.
Jun 22, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Hp laptap pioneer CD wont play
I had the same problem. Go to the link below and follow the directions. Don't worry if you don't have a lower limit directory. I didn't and it still worked. Before restarting go to the device manager and uninstall the driver. I have a similar computer to yours and when I restarted it automatically reinstalled the driver.
http://support.packardbell.com/uk/item/index.php?i=topic_02125&ppn=PB42B00901
Feb 20, 2009 | Pioneer DVR 108 Dual format 16X DVDRW...
PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
Feb 10, 2009 | Pioneer DVR-107D DVD±RW Burner
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Computers & Internet Logo
1,954 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
