Question about Miele CVA615 Espresso Machine
Where can I buy a new brew unit? How much does it cost?
  • 3,230 Answers
Go follow the below link -
http://www.epinions.com/Coffee_and_Espresso_Makers--miele
Please let me know your budget, so i'll provide you more specific information.
Thanks
Posted on Nov 19, 2009
Shutting itself off
There are a couple reasons that the B70 might stop in the middle of brewing so one cannot be certain. The first one is where there are calcium carbonate deposits on the heating element and as the water in the boiler is agitated during pumping there is inadequate heating from the heating element and the thermostat shuts the brewing off when cooler water rises to the thermostat. Try running a mixture of 50/50 white vinegar through the unit a couple timesxto dissolve the calcium deposits or descale the unit per Keurig instructions. Secondly, it could be a faulty thermostat. If you are not handy, mechanically oriented I suggest buying a new one is best, least expensive. I believe that keurig coffee makers are able to brew 5000 cups without a problem. However our experience is that units with more than 5000 brews are prone to leakage, electricalr problems.
Aug 04, 2014 | Keurig B70 Coffee Maker
Giro odea plus not switching on and brewing unit stuck
Your Main power board is most likely gone I could power mine up though. I had used a card to reset the brew group but the error was far more serious, It cost me $350 to have a new power board but the repairer was a bit unsure if I should spend the money and left it up to me, after repairing it he said it is an extremely good coffee maker and I should get the next 6-8 years out of it. they are the last model in this range that was built in Italy and it is worth fixing in my opinion because if you go out and buy something to replace it it will likely cost $$$$ to get one as good. The repairer also commented on the quality of the coffee it makes he was very impressed by this machine so your choice. I also found another one on ebay and purchased it for a $200 it is in great condition but I now have parts and can run two types of coffee :) hope this helps. Kind regards Jen
May 09, 2014 | Saeco Incanto Classic Espresso Machine
Where do I buy a Brew head for v700
All parts are available at Keurig 55 Walkers Brook Dr.; Reading MA 01867
Feb 01, 2014 | Keurig Vue V700 Brewing System - 110774
I removed the brew unit to rinse when I accidentally dropped it. It broke into various pieces. Where can I buy a new brewing unit for the gaggia titanium espresso machine?
Hi, Any domestic coffee machine repairer can get you one. They might even have one in stock, but they canbe very expensive. Up to $300. I do have some contacts in Brisbane that may even have second hand one. Im a repairer Dazza
Sep 05, 2011 | Gaggia Titanium Espresso Machine
Under brewing cup size on a cosistent basis
What model is this unit?
If a B70 or B77, these brewers (usually from Costco) are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of these & they have both been replaced.
Feb 01, 2010 | Keurig Platinum B70 Coffee Maker
My F9 displays Malfunction 8
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. This is usually cured by disassembling, cleaning, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and food grade lubricant for doing this. (I have only been able to buy parts from Europe online) One could by a new brew unit off of e-bay and change out the whole thing. But a simple cleaning or rebuild will typically suffice. One note. The cleaning tablets tend to strip the lubricant from the inside of the brew unit over time. Ocassionaly the seals in the brew unit will fall apart and bind up the unit. Either of these is usually accompanied by a sound of the brew unit motor straining to cycle the machine. If you are not savy in repairing it you may want to send it in. I suspect they will tell you it needs a new brew unit aand quote about $300 USD for the repair. About two hours, much patience, and about $10 in parts is most likely all it may need.
Mike
Jul 04, 2009 | Jura Capresso Impressa F9 Espresso Machine
Miele brew unit jammed and brewunit block is being displayed
There is a third solution. The brewunit drive motor has three contact switches that indicate home, preset (loading grounds, I assume) and make espresso. The problem is the three contact switches are all on one circuit, so the microprocessor knows a limit switch has been reached, but it doesn't know which one. The programming obviously assumes the limit switches are reached in the correct sequence. In my case, the microprocessor thought the brew unit was in home position when it was in the make espresso position. Miele technical support recognized this immediately, so it is a common problem. The solution is to remove the top panel of the unit, unplug the unit, unplug JP34 on the microprocessor board (four wires, red/yellow/brown/black, in the middle back edge of the microprocessor board). Plug in the unit, put it in maintenance mode, and press and hold the medium coffee button for several seconds. This will move the drive motor past the current limit switch. Plug JP34 back in, plug in the machine, and put it in maintenance mode. Press and hold the large coffee button for a second or two, maximum. Open the machine, and look at the brew unit drive male gear in the main machine as compared to the brew unit female gear. It will take several tries to get the male/female gears to match so you can plug in the brew unit. Once this is done, and the brew unit snaps in place correctly, place the machine in maintenance mode one more time and press and hold the Medium Coffee button to reset the microprocessor with the limit switches. You should be back in business!
Nov 25, 2007 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
57 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
