Question about Labtec 961307-0914 Webcam
Connectivity I download the software but I'm stuck on step four connect your device. For some reason its not connecting.
I have the exact same trouble ... i'm starting to think that the camera must be to outdated for the software... what software have you got?
Posted on Jan 15, 2008
Trying to sync my orders through my intermec cn3 and it wont sync. it comes up with unable to connect and error 633...
Hi ..Incompatible drivers might have a conflict with the operating system running your computer
or any of the system software especially with any remote connection or sync software which can cause this issue.
This issue can be mostly resolved by removing any available remote connectivity software or desktop synchronization software. But if the issue is not resolved then the users can try to reinstall the modem drivers and connectivity software.
STEPS to follow
1. Click on control panel>> add or remove programs
2. Select the programs which you want to uninstall
3. Click on the change/remove button to uninstall the software
4. A reboot is required to complete the un-installation
5. Install the connectivity software by using the CD which came along with the USB modem kit or download the software from the provider's website.hope this helps..
Jul 06, 2011 | Intermec CN3
When i connect the cell through data cable it shows usb device not recognise??? why??
try downloading NOkia Connectivity Driver from Nokia's Website... Download and install it...Restart your computer and then connect your cellphone to the computer via Data Cable...
You can download Nokia Cable Connectivity Driver from here:
http://europe.nokia.com/support/download-software/cable-drivers/driver-for-nokia-dke-2-dku-2-ca-42-ca-53-ca-70-ca-101
Dec 13, 2010 | Nokia 3110 Cellular Phone
I just purchase samsung 5253 ( wavw 525) its says gps but i dont find any software and how 2 use it please help thanxs mustafa
settings->connectivity->location
select- enable location services & enable advanced GPS
select my position go outdoors and wait for 05 min u get ur position. it will show u the no of satellites
u can also enable network positioning it will require wifi or gprs/edge connectivity to network
download GPS Locator for BADA it can be used with gps or network positioning but will require internet connectivity to download maps
Nov 09, 2010 | GPS
I have already installed nokia pc suite.but i can't connect my nokia 5130c xpressmusic with my laptop via cable. what can i do?
this is because you did not install nokia connectivity software on your laptop. After install the PC site, you also need to connectivity software.
In case you don't have the connectivity software, you can download it from the below link:
http://www.nokia-asia.com/support/download-software/cable-drivers/driver-for-nokia-dku-5
Good luck.
Sep 02, 2010 | Nokia 5130 Cellular Phone
No network connection for windows xp
Hello kenji, hi, it would really help if you could add more information about the no connection problem, anyway there are several reason why you have no connection;
  1. Bad Lan card, or built in lan port,
  2. Lan card device driver not properly installed, check your driver CD.
  3. loose lan cable. check using a lan cable tester device.
  4. bad router or router setup.
  5. bad dsl or modem setup.
  6. bad telephone connection. check also telephone cable.
  7. no internet service, call your ISP.
  8. if you are using a wireless lan card, check the device.
  9. bad Operating system installation.
  10. check your connectivity setup, is it enabled?
Go through each from one to ten, see which one is the fault.
Jan 14, 2010 | Acer Computers & Internet
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Oct 22, 2009 | Nokia N97 Cell Phone
Scanning Problems
Solution This issue can be caused by the way the USB chips in the product and the USB chips in the computer interact, or it could be caused by an old version of the HP software and driver. First, make sure that the most recent version of the HP software and driver is installed on the computer, and then try testing the USB devices and ports on the computer. If the product still does not scan correctly, a powered USB hub might help resolve the USB communication issue. Follow these steps to test the USB connection and see if a hub is necessary. Step one: Make sure that you have the most recent version of the HP software and driver The HP software CD that shipped with the product frequently does not contain the most recent version of the software and drivers. To make sure that the software is the most recent version, download and install the most recent version of the software from the HP Web site. The software and driver downloads available from the HP Web site include a Basic Driver option and a Full Feature Software and Driver option. The basic driver is sufficient to perform basic printing functions with the product. The Full Feature option installs extra software to allow full use of all features available with the product. The Full Feature option also allows custom installation. Follow these steps to download the software from the HP Web site and install it on the computer.
  1. Click here to go to the HP Software Download Page .
  2. In the Enter a product number text box, type the product model name (for example, HP Photosmart C3180), and then click Submit (c01425574.gif ) or press Enter .
  3. Under Product search results , select the product model name from the list that appears on the computer.
  4. Select the operating system that is installed on the computer. The Select Software and Drivers page appears.
  5. If the Automatically check to see if you have the latest software and drivers link appears at the top of the page, click the link and then follow the on-screen instructions to check the software and driver version and update the software if necessary. If the Automatically check to see if you have the latest software and drivers link does not appear at the top of the page, continue with step 6.
  6. In the Driver section, review the list of available driver downloads, and then click the appropriate package.
  7. Click Download Only and then follow the on-screen instructions to download the software.
  8. To install the software, double-click the icon for the downloaded file and then follow the on-screen instructions to complete the installation. CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 3 m (10 feet) long.If any firewall messages appear during installation, click Unblock or Accept or the installation fails.If the User Account Control screen opens, click Allow to continue.
Step two: Test the USB connection
  1. Disconnect all USB devices, such as printers, scanners, speakers, and cameras, from the computer except the mouse and keyboard.
  2. Connect the USB cord from the HP product to a USB port on the computer that is known to work correctly. Test the connectivity related functionality of the device (for instance: scan to file.)
  3. Print a self-test page from the product. NOTE: For information about how to print a self-test page, see the user guide for the product.
  4. Test the standalone functionality of the product by using the product control panel to scan a document or an image. NOTE: For information about how to use the product control panel to scan, see the user guide for the product.
  5. If the scan from the control panel works correctly, connect one USB device at a time to the computer and test the product by scanning from the control panel after each device is connected.
  6. If the product scans correctly from the control panel after every other USB device is connected, the USB connections are working, and you have resolved the issue. If the product does not scan correctly from the control panel or does not establish communication with the computer after a USB device is connected, the computer might not have enough power to run multiple USB devices. A powered USB hub might help establish or maintain communication between the computer and the product. Go to Step three: Use a USB hub.
Step three: Use a USB hub A powered USB hub might allow all the USB devices to receive enough power to run correctly and it might resolve USB communication issues between the product and the computer. Follow these guidelines when choosing and setting up a powered USB hub.
  • Make sure that the USB hub is a powered hub and the power adapter is included. Some powered hubs do not include the power adapter as a standard item.
  • When setting up the hub, it must be plugged into a power source.
  • Some hubs cannot handle more than four full-power USB devices, such as the HP product. To connect more than four full-power USB devices, use more than one powered USB hub. Most Windows computers can support a maximum of five USB hubs.
  • If there are multiple USB hubs connected to each other or if there are more than four USB devices connected to the hub, the issue might persist. Move the HP product to the hub that is directly connected to the computer USB port.
Workaround If these steps did not resolve the issue and purchasing a powered USB hub is not possible, the issue might be resolved by turning off the Preview option in the HP scanning software. NOTE: This workaround does not resolve problems scanning from the control panel. Follow these steps to turn off the Preview option.
  1. Click Start , click All Programs , click HP , and then click HP Solution Center . The HP Solution Center window appears.
  2. In HP Solution Center, click Settings and then select Button Settings .
  3. Clear the check box next to Show preview when scanning from the Scan Picture button and then click OK .
  4. Quit HP Solution Center and then try scanning again.
May 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
GPS to software communication issue
look in the options of the software ... choose auto or usb for communication with the garmin
Jan 10, 2009 | GPS
CONNECTIVITY OF DATA CABLE WITH PC
I download the driver from the below form .download and enjoy.(usb driver)
Sep 13, 2008 | Handmark Software MobileLists (950142) for...
Labtec 961307-0914 Webcam Logo
43 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
