Question about IBM IntelliStation M Pro 6219 PC Desktop
No video output on IBM Intellistation PRO M, model 34G. How do I figure it out? Replaced vci card with pci vga card.
  • 22 Answers
To confirm if your external vga card is defective you should turn off your pc then remove it, then turn it back put your vga cable from monitor in the built in vga port in you pc. or else after turn on press numlock twice or more if its work then external vga is the problem.
Posted on Nov 19, 2009
Beep codes
Try taking out the RAM (memory) cards and reseating them. Same with video card (if it's got a plug in(PCI-e/AGP) card)
If it is beeping constantly suspect a fault with overheating on the processor. Is the fan on the CPU working? Might be the thermal compound between the heatsink and the processor has gone bad and needs redoing ...
Oct 14, 2013 | IBM IntelliStation M Pro 6219 PC Desktop
Hi..just tried an install of HD4650 video card, it had no POST screen, only beeps in Phoenix BIOS : 2-4-1. (No 4th report...There should be one more according to my searches) I don't know what this...
If this is your card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102829
It has a 2.0 x 16 slot requirement that may not be compatible with your system. If this is your prior card:
http://www.overstock.com/Electronics/Nvidia-980XGL-128MB-Quadro4-DVI-VCQ4980XGL-Video-Card-Refurbished/5539014/product.html
It is AGP 8x, which i a totlally different setup. I looked up your system and it has AGP 8X slot:
http://www.bing.com/shopping/ibm-intellistation-z-pro-6221-xeon-2-8-ghz/specs/71BB88F57E2979DCBF33?q=ibm+z+pro+6221&lpq=ibm%20z%20pro%206221&FORM=HURE
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125281
It would work, providing you have 400w power supply and a 6 pin connector to hook up.
The only way I can clarify what you've got and whether it's actually compatible, I need the make and model number of the card you have. You can see there are alot of different options.
Note: after looking again at the specs for you system, it comes with a 425w power supply. If you have your case open look at your power supply and it should say on it what the supply is.
Dave
Jun 17, 2011 | IBM IntelliStation Z Pro 6221 PC Desktop
I am not geting suitable driver for IBM IntelliStation E pro 6226 model
try download driver here:
http://www-947.ibm.com/systems/support/pc/
Mar 27, 2011 | IBM IntelliStation E Pro 6226 PC Desktop
No audio output with winxp sp2
download the rihgt drivers for your motherboard.
try this one:
http://www.drivershq.com/Drivers/Devices/IBM-IntelliStation-M-Pro-SoundMAX-with-audio-Drive/1916/19/Drivers.aspx
Aug 06, 2009 | IBM IntelliStation M Pro 6849 PC Desktop
The computer turns on but there is nothing coming on the screen, its not the video card because i just bought a new one to put in
Hi..
Besure that the video card you inserted are correctly inserted you need to check it first. You need also to installed the vieo card driver. If the sam things occurs you need to disassemble the unit . Try to remove the proccessor and clean it after that insert it again. Check all the power cord and cable wire if it is correctly install in their respective port.
Thanks for using fixya..
Regards
ICmanServer
Aug 05, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
IBM Blue Screen
I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
System:
IBM 6868 52A M-Pro Intellistation
2 x Intel P3 866 CPU's 256 mb cache
2 GB ECC RD Ram
2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
ATI 9520 AGP 128mb Graphics
Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
Dual Boots with Xandros Linux Desktop Destop 3.01C
Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
I get no video output from the new PCI video card I've installed in my Think Centre
Maybe your old video card is on board because you don't mention it that you remove it. Maybe the problem is the cmos or the bios setup. If you can go to bios setup look for the onboard vga in disable it and look for pci vga option if disable enable it. or try to transfer the new pci video card to the other slot maybe the slot is damage or corroded that's why the contact to the board in not fucntioning.
Apr 16, 2008 | IBM ThinkCentre A50p PC Desktop
IBM IntelliStation M Pro 6219 PC Desktop Logo
224 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
