Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony 50" Projection TV problem
I have a Sony 50" projection TV that when I am watching goes blank while the sound remains playing as normal. this is the same case when I play Games on the TV. What can cause this to happen?
  • justme24 May 11, 2010
    is this only when using hdmi feed?
  • 834 Answers
This set is getting up in years you have a weak CRT that is shutting down the pix
sony has what is call an IK curcuit that wants to see equal outputs on the crts so youget true color any way you need crts not avail anymore sorry
Posted on Nov 19, 2009
Lamp replaced 1.5 years ago, now the picture goes out but comes back on every few minutes, as if it gets to hot and needs to cool down. Fan comes on.
Lamps only last for 5,000 hrs -8,000 Playing hrs
It means every hour you Play TV Lamp burns up the hours, so after 5,000hrs on most Lamp needs replacing, some Lamps dont even last this long DLPs are not like Projection you can play them 24-7 and Tubes will remain good, But Lamps are like a light bulb they all burn out after so many hours.
Best thing is to turn TV off if you are not watching it, in order to Save Hours burt on Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Replace the Lamp.
Mar 05, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I get curved red lines and then screen goes completely red and no sound
This is symptom of defective red picture tube in TV that needs to be replaced.
Let me know if you want to replace it by yourself to provide you part number info or call tv tech to do the job.
Thanks.
Nov 30, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
While watching tv the screen goes blank and the green light blinks where it says power standby before it was every now and then now its every 5 mins
Replace your Lamp call Mats 1-800-628-1118 Also you may want to pull back just to make sure the Lamp housing is clean of dust and dirt Fan as well must be clean. If everything is clean order Lamp.
Sep 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
50 inch Plasma problem
Most likely a capacitor in the power supply went out. otherwise it may be a bad relay if there happens to be one.
Most reason for a tv not turning on at all is bad power supply
Aug 01, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
LAMP
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
TV Goes Blank after 5 minutes
If the lamp indicator stays red then you do need to replace the lamp if not without a service manual for your tv its difficult to trouble shoot the problem but if you don't have one you can get one at this sight along with free online tech support
http://servicemanuals.vstore.ca/
Apr 29, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Grand Wega picture going on and off; standby light flashing, sound remains on
Is the cooling fan running properly?  I'm just guessing, but it sounds like it could be overheating and shutting off, which allows it to cool off enough to turn on and overheat all over again.
Dec 09, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
146 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
