Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
No Picture on Viewsonic TV
By mehdi123 on Jan 11, 2008
We have a 32" ViewSonic televeision. Webought this TV about 13 month ago. When I tried to turned it on tonight, the picture did not came up. The audio is okay, Remote is working but no pcture. Please help. This is our only TV set.
Thanks
Med
Clarification Request
Posted by Rocket80 on Feb 28, 2009
dkomher
You said your problem was a chip in the power supply. Could you be a little more specific - chip name/item number? Where did you purchase?
Thank you
Sid
Same Problem
Apr 11, 2009
-   I own a viewsonic 32inch also but i didnt get any sound and no picture either, but before this happened I also noticed on the right side of the screen i was getting a green cloud....sort of a fade.....Could this be something else or is this the same problem with the power chip?? -   Guest
Jan 16, 2009
-   no picture only audio -   Guest
Jan 09, 2009
-   My 32 inch ViewSonic LCD works perfectly when you turn it on, but after 5-10 minutes a high pitched squeel starts and the screen goes dark (sound still works.) I want to repair but have no idea what needs replacing... -   evstock
Jan 06, 2009
-   no picture on tv. N1800 -   Guest
Dec 21, 2008
-   my 32 view sonic went out 30 days after warrenty got no help from frys electronics or view sonic left it at frys said its paid for fix it and keep it i am sure someone did!-   kng4adae
Best Solution
posted on Jan 16, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
That is a coincidence. My tv went out the same night. But mine wont even turn on at all. So far I have had no luck finding anyone to repair it. Let me know if you figure something out and I will do the same.
Solution #2
posted on Jul 01, 2008
Somewhat Helpful)
btownlite
Rank: Apprentice
Rating: 70%, 1 votes
same thing happened tonight. was watching tv as usual, and then out of nowhere, tv lost picture, sound and all the rest, and then turned off a few seconds later. went onto viewsonic's website and found the self help thing, went through every single step, with no help. tv will not turn on. did it overheat or something?
whats the deal?
Was this helpful?
Yes
No
Solution #3
posted on Nov 07, 2008
Not Helpful)
dkomher
Rank: Apprentice
Rating: 52%, 2 votes
Had a problem with 32'' viewsonic.No picture and had sound.Fix is a chip on power supply($15.00) part.I replaced and all ok now.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Oct 31, 2009
Not Rated)
tryune
Rank: Apprentice
Rating: 100%, 2 votes
There's 2 main issues I've had with this LCD TV I have a 40" one is the power will go and you won't be able to turn it on although you can hear a click when you try to. For this you need to replace the power board or what they call the inverter board you can order it direct from the viewsonic site (store.viewsonic.com)
The other problem is that the video will go out I had this happen about a year after I replaced the inverter board for this you'll need to replace the Main board. I recomend that if you get the power issue first just replace the main board assembly because I believe it comes with the inverter board (it did with mine). For my 40" tv it was $658.13 plus 42.78 tax and 6.60 shipping total $707.51. Hopefully that helps you decide to buy a new one or repair it.
Was this helpful?
Yes
No
Solution #5
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem and I was told by a repair man to replace the main power supply or the lcd controler board. May cost about $200 to fix. Wbesite is shopjimmy.com I change the parts and tv woks fine.
Solution #6
posted on Sep 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you know what the issue is you can call View Sonic directly and order the parts. I was told by View Sonic support that they do not have authorized service dealers any where. So if you can get someone to at least diagnose the issue you can then order the parts yourself. I know not the best solution but might be cheaper than buying a new TV right.
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
which is better? samsumg plasma 32 inch or devant plasna 32 inch? can you please give me the... (More)
Answer
What is the best flat-screen on the market?
Answer
I have the lg dat 250 tv/dvd but no manual. cant seem to set it up without one
Answer
i have deleted channel 4 by accident on my television, i want to get it back but don't know how.... (More)
Answer
Hi, What is the sky remote control code number for the TV M2762D. Thanks.
12 Other Users Have The Same Problem - Continued
Comment by dragnet, posted on Aug 25, 2008
I also have the same problem with my 27" ViewSonic flat screen TV.  I left it off for about two weeks and the picture came back for about an hour.  Then it returned to total darkness.  Like yours, the audio and remote are fine.  Can't find anyone to fix it.  Are screwed?
Comment by dkomher, posted on Aug 24, 2008
no picture.Sound and remote work
Comment by banea_b, posted on Aug 02, 2008
Just happened right now on my 37'' Viewsonic LCD TV. Image went black. Sound works and so does remote. Tv is about 13 months old. Powered off powered back on no image. Any help ??
Comment by Guest, posted on Jun 12, 2008
Purchased a 42" lcd viewsonic about 18 months ago and when I turned on the tv last nigh...NO PICTURE. Just sound,. The remonte and tv controls do respond to channel and volume changes...just can't see anything. We unplugged tv, replaced cable wire...didn't help
Comment by helpme5463, posted on May 03, 2008
Same issue. My picture appears when I turn the TV on and then goes dark.
Comment by caaableguy, posted on Mar 24, 2008
Viewsonic 32". My LCD tv is 16 months old and has the same problem. It also has a high pitch squeel when it goes dark as well. Does anyone know the cost of this repair?
Jim
Comment by Guest, posted on Mar 13, 2008
i have a 40 inch and the same thing happened to me also a viewsonic and no luck on getting it fixed just yet they say it is hard to get parts. this also happened to me at about 13 months and it has been in the shop for about 3 months now
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel Televisions Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
