Question about Motorola Mobility i425 iDEN Cellular Phone
I'm trying to down pics to my i425 but when i plug it in via usb cord it says its a modem what do i do
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
Have a i1237 polaroid camera, with a usb cord, i plug it in to my computer and doesnt give me an option to upload pics.......thought that was what the cord was for? how can i upload my pics?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
Jul 22, 2011 | Polaroid i1237 Digital Camera
When I plug my camera (cannon A560 powershot) into my computer using a USB cord, the camera screen goes blank and a green light blinks. I can't upload pictures on my computer anymore. I just recently got a...
Try NOT using the USB connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 08, 2011 | Canon PowerShot A560 Digital Camera
Coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
Feb 07, 2010 | Nikon COOLPIX L3 Digital Camera
Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Jun 08, 2009 | Arris Touchstone 450a (CM450) Modem
I can't save ringtones via email attachment to my i425
Boost Mobile does not accept ringtones from 3rd parties, whether its sent via email or mp3 attachment. U might want to try sending it through the SMS. Maybe u can save it that way. Only way I've been able to get ringtones is thru the Boost site only. No "free ringtone" websites are able to send ringtones thru a message, cuz Boost blocks this. And Ive tried them all. Until they provide us with phones with SD cards, were outta luck, sorry.
May 27, 2009 | Motorola Mobility i425 iDEN Cellular Phone
How To: USB hookup for computer while having ethernet hookup to Xbox 360.
USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
May 21, 2009 | Westell Wirespeed LiteLine 6100...
Downloadable drivers
Yes you can download the drivers via www.motorola.com and go into the support section, choose your phone model and get the driver. You can also Google for them.
Jan 07, 2009 | Motorola Mobility Boost i415 Cellular...
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Motorola Mobility i425 iDEN Cellular Phone Logo
121 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
