Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
How do i insert a memory card in this phone? - AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
This phone supports large-capacity TF card. TF (T-Flash) cards are also called Micro SD cards. First power off and remove the battery cover and battery. Push the T-Flash card slot upward and slightly pull it outward and insert your TF card into the slot with the nicked corner on the right and the metal contact points facing inward, and then cover the slot. Note: TF card requires anti-static operation; do not place your TF card in your pocket, do not touch the metal contact points and keep it out of the reach of children. Do not try to insert or remove your TF card while power-on.
Posted on Nov 19, 2009
Testimonial: "Thank you so much :)"
I am getting no memory card inserted
Remove your battery
insert your memory card
insert your battery
Power On.
if still no memory card inserted
Replace your memorycard
something wrong with your memory reader (parts of cellphone)
Jan 19, 2013 | Nokia N73 Cellular Phone
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
Memory card no dedect,and no files in displade.
Hi,when a memory card does not detect on phone, it simply because the the memory card you inserted into the phone is not properly fixed or the memory card you inserted into the phone is damaged,that's when if doesn't detect the memory card on the phone.
You can insert the memory card inside a card reader or a friends phone that uses the same memory card type to confirm if the memory card is not damaged yet.
I guess that will solve the problem.
Take care.
Oct 11, 2010 | Sony Ericsson G502 Cellular Phone
5800 MMC NOT WORKING
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
To test if it is the memory card
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Jun 18, 2010 | Nokia 5800 XpressMusic Smartphone
How to insert Memory card into sony ericsson w350i mobile
To insert your memory card into the phone,
You remove the battery of the phone, underneath the battery by the lower end you will see the slot where you will insert the memory card.
The direction on inserting it is shown in the phone.
Take care
Jun 13, 2010 | Sony Ericsson W350i Cell Phone
When i insert my memory card in the slot than the phone didnt show the memory it tells insert memory card..........
The memory card is not good, please, try and change the memory card and insert it. Thanks
May 20, 2010 | Lands Phones
Message says - memory stick not inserted
Dear,just format the card with computer through a card reader and insert the cardinto fone then format the card by ur fone and then check, if problem presists then ur fone's card jacket is not working so then you will need to go to a certified mobile fone repairer to get changed your fone's jacket. its not very expensive..thanks
Apr 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
I have re-inserted my memory card of Nokia N73. but is showing "memory card not inserted"
ur memory card may damaged or used password in memory card. pls check other phone to confrm
Jan 11, 2010 | Nokia N73 Cellular Phone
Get Memory card not inserted
simply check the memory card through card reader if it works then u have to check the socket of phone where the card is to be inserted..
that one is causing problem...may be its pins are not propely being connected with the memory card..
if  the card doesnt work even with memory card reader then the card is faulty...or if u dont have memory card reader just put your memory card in another compatible phone to check..
or get another card and put it in your phone for checking..
hope it will fix the issue so dont forget to rate it...
Jul 06, 2009 | Nokia 5800 XpressMusic Smartphone
Mmc
Chances are that the software on your phone has become corrupted. I would advise doing a master reset on the phone and see if the problem persists. If that doesn't help...probably the card slot has malfunctioned. Most probably a reset will slve the problem. Good luck!
Dec 19, 2007 | Nokia 6680 Cellular Phone
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
197 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
