Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
Ext 500G Fantom HD turns on but won't boot up.
Ext 500G Fantom Drives HD turns on but won't fully boot up. Clicking noise from the drive like it's trying to start up every second or so. The blue light doesn't come on any more. What's the problem? Can I fix it?
  • afcook Nov 23, 2009
    I've had the hard drive for about 2 years with no problems. There doesn't seem to be anything wrong with the power supply, computer, or computer port. Yes it's USB 2.0. The clicking sound indicated to me that the hard drive isn't spinning properly inside its casing. Power is getting to the device, but the drive won't fully "boot up" or run.
  • 358 Answers
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Hard Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Posted on Nov 19, 2009
  • Dammy Ezekiel
    Dammy Ezekiel Nov 23, 2009
    From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
    That clicking sound that you are hearing from the Hard Drive is coming from the read/write head inside the hard drive.
    In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
    If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
    Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
    It works through DOS, and it should be able to help you with it.
    If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
    And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
    Good luck.
I have a clicking 500GB Fantom that I can not see in "My Computer" no drive letter exists.
If you drive makes loud clicking sounds it is likely that the drive has experienced a "head crash"
and it is toast.
You van always take it to an expert but they charge a lot of money.
I work on drive all the time and I'd say it is 98% likely that it is toast.
Sorry about that.
Jul 23, 2011 | Fantom Drives G-Force (GF500EU) 500 GB USB...
Fantom hard drive not working
When you hear that clicking noise that is the head and it is stuck. At this point the only way to recover the data is send it to a recovery expert firm. The issue is that the head(the part that reads the data) is stuck and essentially beyond normal repair. There truly isnt much you can do I am sorry to say
Mar 17, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive not being detected
I don't think it's a power related issue. Hard drives are very sensitive, swapping the two HD would cause a problem. Do you hear a clicking sound while the HD is turned ON? If you do, I'm regretfully informing you that the HD is starting to quit working. Bad sectors are starting to increase.
I would advise you to try connecting the problem HD to another computer. If the HD is detected by another computer, back up all the files and then reformat the problem HD. After reformatting the HD, restore the files that you back up from another storage and it should be working again.
Have a great day!
Sep 20, 2009 | Fantom Drives 120 GB Hard Drive
Same thing
if its making a loud clicking noise i would guess that the hard drive got jolted hard while shipping if possible send it back and get another one or if you have another hard drive put it in install windows and discard other drive very rare for them to get damaged during shipping(maybe you can get them to just send hd(hard drive)and drivers instead of whole computer!!!
Sep 06, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Data recovery from External HD
Matthew,
First thing you should do is remove the drive from enclosure and connect it direcly to the PC or via another USB enclosure.
If it still doesn't power up then most likely the PCB is dead. You can try to find another drive of the same model and swap the PCBs. But as far as I know often this doesn't work.
Here's some info about burnt PCB (in the beginning): http://datacent.com/datarecovery/hdd/western_digital/
Take care.
Nov 03, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom Titanium Hard Drive - 500GB
You can remove the drive from the casing and connect it inside your pc, using IDE cables if its an IDE or a SATA cable, if it comes with one
Dec 26, 2007 | Fantom Titanium Hard Drive
Drive NOT being recognized by WinXP
Put your ear to the drive and verify if it is making any strange low level sounds. Check to make sure the usb connection wasnt affected. YOu wont need a driver as it appears to be hardware related. Either the enclosure or drive may be failing.
Oct 24, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Oct 01, 2007 | Fantom Drives EXT HD 80GB| MTT80 RTL Hard...
Open Questions:
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
510 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
