Question about Dell Inspiron 6000 Notebook
Motherboard or Hard Drive problem
I have a DST failure when I had a diagnostic test and I was wondering if it was a problem with the motherboard or the Hard drive? How can you tell and test for it?
  • Omanye Aba
    Omanye Aba Jan 22, 2008
    My system shut itself down. I downloaded drivers and rebuild, start-up was ok but got a message with about .....kernel...,uninstall any new programs installed, beginning to dump hard drive,...
    System couldn't start-up again, when checked, nothing was found on the hard drive. Everything wiped off!! Had it rebuild again, then similar message, system shutdown, couldn't start up. Message, no rebut on hard drive.
    Any help out there please. Is it the hard drive or motherboard problem?
    Genius:
  • 1,226 Answers
Testing mother board:
1. remove memory:
if the mainboard produce long beep means good.
if not that is bad.
2. if produce long beeps then insert the memory.
3. if same happen.hear long beep. then clean or replace memory.
If your are sure evething is ok in the mboard; then you can test your drive:
Hard drive test:
1. first fixed well all the connection bet the HDD.
2. if work then ok, if not then,
3. replace other IDE cable/ sata cable and fixed well again.
4.if still thesame; then
5. examine your HDD , the circuit maybe shorted.
Posted on Jan 11, 2008
1000-0143 Dell error
This error code is related to " Drive Smart read command failed."
POSSIBLE LINK to fix: -
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#HDD
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
Mar 04, 2012 | Dell Latitude D810 PC Notebook
Error message 2000-0151 on dell inspirion 1545
Hi.
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
  • 1000-0146
  • 2000-0146
For instructions on how to run the Dell 32 bit diagnostics click here.
Regards.
Sep 05, 2011 | Computers & Internet
I did a diagnostic run and error message 2000-142 Hard drive dst test status 79 came up. what can I do to fix this problem
The dell diagnostic is an inbuilt tool that helps to identify the hardware failures...
This 0142 error occurs if the Hard drive has gone bad.. It is due to a hardware failure in the hard drive.. So toy have to replace it... If you have warranty on the computer you can call dell(18006249896).. If you dont have warranty then call any local computer shop and replace the hard drive
Nov 01, 2010 | Dell Inspiron 1525 Notebook
OptiPlex SX280 PC Desktop: Blue screen, ran diagnostics, chatted with Dell to...
You'll have to make a backup of it before you reload. But I was wondering, if you have found via the diagnostics that a possible hardware component has failed why do you need to reload the OS?
Another thing to look for on this model of Dell is capacitors on the motherboard that may have become swollen or burst. Dell had a series of defective motherboards in this era, and your model is one of the ones affected.
Of course, if the motherboard has swollen caps, you'll have to replace it, unless somehow its still under warranty and then dell will send you a new one.
May 18, 2010 | Dell OptiPlex SX280 PC Desktop
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
My laptop is a dell 6000 and it says there are no bootable devices
your hard drive has failed, on boot (dell splash screen) press f12 to bring up boot menu, choose diagnostics option, run this and it should confirm hard drive failure on dst short test (drive self test) and give an error code (e.g 2000 - 0142), trust me on this i am a dell field service engineer
Jan 14, 2010 | Dell Inspiron 1525 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
DST Error Motherboard or HD problem
What is the manufacturer of the PC?
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
87 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
