Question about Apple iMac Blueberry Mac Desktop
Modem commands modem wont accept commands from AOL server
  • 382 Answers
Modem? LIke dial up 56k modem?
Posted on Jan 11, 2008
How to change the server aol to my google chrome on start up
Dynamic host configuration protocol (DHCP) is a way to configure IP addresses and TCP/IP settings throughout your network.
The DHCP service is run on a machine with a static IP address so that the computers on the network can find it for automated configurations.
Setting the IP address on a Windows 2003 server is accomplished through the network configuration settings in Control Panel.
Click the Windows "Start" button and select "Control Panel." Double-click "Network Connections." In this section, double-click "LAN Connection."
This opens the configuration tool to set the IP address of the server.
Select "TCP/IP" from the list of configured network applications and click the "Properties" button. This opens a new configuration window.
Select "Use the following IP address" to set a static IP for the server.
Enter the IP address chosen for the server in the first textbox that is activated.
Enter the subnet mask and default gateway for the server.
The default gateway is usually the router on the local network or the DSL or cable modem on a small, home network.
Enter the DNS server address.
The DNS servers are separate servers on the network.
For small, home networks, the DNS server is provided by your service provider.
Click the "Ok" button to save the settings. Click "Ok" again at the general LAN properties window.
Renew settings on local computers. Computers that use the DHCP server for configuration need to be rebooted.
You can also use the DOS command prompt to renew settings.
The "ipconfig -renew" command refreshes the settings on client computers on the network.
or for home page browser
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have
have if dont need any of them you can disable or remove them
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
Hope this helps
Dec 29, 2012 | Google Chrome
I am using VSI fax on a server running Windows Server 2003 and I have recently had problems with the modem loosing connection with the com2 port. Is this a problem that occurs with vsi fax? Also, my...
iv had the same problem also with a multi-tech comm modem, only way i'v found to get the problem fixed is to restart the server and run command vfxserver start
Apr 10, 2011 | Esker VSI-FAX
My Voyager modem will not recognise AOL server.
***** ****** Well Dahlin' , you got questions. Check out the forum I found .. the folks are a hoot. I got a kick out of it none the less. Now back to you, I think the answer lies toward the end of the page there's two different answers that should work. If not a couple of other stuff to try. Good luck. Hope it helps, if it does please rate me. thanks-jmattes
Sep 26, 2009 | Dell Computers & Internet
How toconfiguring windows2003 server as router
chk step wise step
Apr 11, 2009 | Computers & Internet
Router and Aol server not conected.
With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It will search for your connection, find it and allow you to log on.
Configuratin instructions can be found here
Feb 10, 2009 | NetGear DG834 Router
Need help
it doest matter if you have the disk or not. Access the command prompt window, type in "ipconfig" press enter. Make a note of the default gateway. type the same set of no.s in the address bar of the interent explorer, you will acess the modem's Graphical User Interface. If it asks you to enter the user name and password type in user: admin password: admin or leave it blank.
Try to enter the uid and the password from ISP, you should be connected.
Sep 23, 2008 | Efficient Networks (060-5660-003)...
Wont conect to internet
hi. sir.
go to the internet option>
setup> choose which type u need to do>
see whether the modem is enabled first. thank u. sir
Sep 03, 2008 | Dell Inspiron 1100 Notebook
Modem Problem?
In order to really test your modem you need to call more than just 1 (your ISP's) number. If you are not getting 56k connects, you should try your modem with other local/toll/toll-free numbers. This is a list of some toll-free numbers, the 3Com "Line Test" Number (a toll-call), and links to various ISP local access number listings Setting up an account with a Free ISP is another way you can test and isolate modem/ISP problems.
1-847-330-2780 - USR Linetest number - this is a toll call; if you log-in as "Line Test" with a v.34 modem, it will attempt to determine if your line will support 56k connections.
1-847-330-4569 - US Robotics' V.92 Test number - this is a toll call; the server is a 3Com Total Control HiPer ARC running V.92 server side code that supports PCM upstream.
The following numbers use toll circuits but are free to the caller (as long as you don't log in):
1-800-245-3828 - (Canadian weather BBS)
1-800-590-4857 - (IBM Global network access # x2 and V.90 3Com Server)
1-800-784-3638 - (Netcom - supports V.90)
1-888-861-8490 - (MCI/Worldcom))
1-888-245-0113 - (AOL access x2)
1-800-716-0023 - (AOL alternate access)
1-888-296-3892 - (AT&T Worldnet accessV.90,x2)
1-800-638-1483 - (GTE Net access - V.90/K56Flex Ascend Server)
1-800-572-1959 - (Compuserve V.90,x2)
1-800-350-6885 - (Earthlink - V.90,x2)
1-800-853-7921 - (Earthlink - Flex)
1-800-534-7097 - (Earthlink - Flex)
1-800-304-4226 - ( - Flex)
1-800-320-4509 - (Ascend 56KFlex test line)
1-800-779-2966 - (Used to be MCI)
1-800-846-7562 - (Gateway BBS)
Apr 03, 2008 | Agere (DSLU56KPCI) Modem
Apple iMac Blueberry Mac Desktop Logo
29 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
