The light in the freezer section burned out and I cannot find a replacement. The hardware store said the light is European. Where do I get a new light bulb?
  • 11,896 Answers
You can get one at repairclinic.com or partselect.com
Posted on Nov 19, 2009
We just got our new frig anf freezer is blinkinf h1 what does this mean
Hello;
My name is Peter. I am a retired field service refrigeration technician.
H1 is really HI. Your freezer is too cold. You only have one source of cooling and that is your freezer. You freezer also cools your fresh food section. Your freezer will meet its temper setting before it meets your fresh food section.
The normal setting for the freezer is -2 to + 2 degrees F. and the normal setting for your fresh food section is 35-40 degrees F. Adjust to these settings. Wait 24 hours for your system to stabilize.
If the error code does not go away or your freezer and fresh food section are reasonably within the above settings, then you need to contact the store where you purchased it.
It is not uncommon for a new unit to be delivered one day and I am there the very next.
Feb 26, 2015 | Frigidaire Refrigerators
Frigadare refrigertor side by side its cooling fine but the freezer wont freeze
Check the heater coil in rear of freezer. Mine was burned out. Letting ice build up on the cooling fins. Replaced with new type double heater coil and fixed proble. You'll have to remove the cover off rear wall of freezer section to access it.
Jul 04, 2014 | GE GSS20IEP Side by Side Refrigerator
Light bulb is not working. how to change it and what kind of bulb is it model: FKFH21F7HW
Good Afternoon Rose, I am happy to assist you!
Before replacing the light bulb in your Frigidaire freezer please confirm that the temperature control is set in the OFF position and unplug your appliance to avoid electrical shock. Typically, you may remove the light bulb by turning it counter-clockwise. The old bulb can be replaced by an equivalent watt bulb (part number is 216988100) available either from part distributors or hardware stores. I hope this information helps to some degree!
Feb 25, 2014 | Frigidaire FKFH21F7HW Freezer
Light bulb replacement
Try a APPLIANCE PARTS/REPAIR shop..... If they can not get it for you, it can not be gotten....
Jan 09, 2014 | Woods Chest Freezer C1501W3
WHIRL POOL STAINLESS STEEL FRENCH DOOR- BOTTOM FREEZER MODEL NUMBER GI5FSAXVY
You should be able to buy replacement stripping at any local hardware and furniture store.
Sep 16, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
Rear turn signal b ulb burned out - How to replace
Rear Turn Signal, Brake and Parking Lights
  1. Remove the tail light assembly screws, then the assembly.
  2. Disconnect the twist lock socket from the lens housing. NOTE: To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise 1?4 turn, then remove the socket with the bulb; replace the bulb if defective. Fig. 7: Remove the tail light assembly screws, then the assembly - wagon shown 86816223.jpg Fig. 8: Twist the socket counterclockwise to remove from the housing 86816225.jpg Fig. 9: This type of bulb simply can be pulled out of the socket for replacement 86816226.jpg To install:
  3. Attach the socket assemblies to the back of the lamp unit.
  4. Install the lamp assembly to the vehicle with the mounting screws.
License Plate Light
  1. Remove the lens screws.
  2. Once the lens is removed you, can access the bulb and replace if needed. To install:
  3. Install the new bulb, then attach the lens to the body of the vehicle.
Center High Mount Stop Lamp
  1. Remove the screws securing the lamp cover.
  2. Remove the mounting nuts, then unplug the electrical harness to the lamp assembly.
  3. The lamp now should come out. To install:
  4. Position the lamp assembly to the vehicle, then attach the electrical harness to the lamp.
  5. Install the mounting nut, tighten to 62 inch lbs. (7 Nm).
  6. Attach the lamp cover. Fig. 10: Exploded view of the center high mount stop lamp assembly - wagon shown 86816230.gif
    Fig. 11: Light bulb application chart for all models with non-European headlamps 86816237.gif
    Fig. 12: Light bulb application chart for Buicks with European headlamps 86816235.gif
    Fig. 13: Light bulb application chart for Oldsmobiles with European headlamps 86816236.gif
Dec 19, 2010 | 1994 Buick Century
Refrigerator section does not cool. Light or LED behind refrigerator control knob does not light so you can not see the current setting. Freezer section works fine as does the freezer control knob light.
these refrigerators are notorious for a bad main/mother-board being bad,especially if recently you had light bulbs have burned out in the refrigerator compartment as this creates a surge on this board and burn the printed circuit trace on the board,it is located in the lower rear of the unit and is housed in a plastic case and if you open the case and look at the board and case there will be a burn spot on the plastic case also
Mar 13, 2010 | GE GTS22WCP Top Freezer Refrigerator
LIght is out in freezer. How to replace and can I do it myself?
Yes you can do yourself
Usually in a medal frame - use screwdriver to pry gently away - inside is a module with bulb - a number will be on it - just take out and insert new one and put frame back
You can obtain at an appliance parts store or on ebay usually (mine costs about $10-$12 at appliance store.)
I thought you meant the power light on freezer but
on reading it again looks like you mean in freezer - same idea but it's more likey a fridge / freezer bulb - just take off the panel and take your sample to a lighting or hardware store or contact manufacturer on their website if it is an oddball bulb.
May 09, 2009 | Refrigerators
Fuse 17 Failure - 98 Range Rover
some european cars burns abs fuses when the electrical system dont have the optimal voltage (at least 12.5 v). check chargin system or battery connections
May 01, 2009 | 1999 Land Rover Range Rover
14 people viewed this question
 Grubhead
Grubhead
