Question about Lenovo IdeaPad S10-1208Uw Netbook
Lenovo s10 able to boot up but no display on screen
Hi there, my lenovo s10 is able to boot up but i cant see any display..i have tried fn f7 but that did not help..any other suggestions to try?
  • jay2230 Nov 19, 2009
    Hi thanks but there was no such problems as mentioned. ntbk was not in used for 2 or 3 wks and after booting up, there is just no display.
    i will try to connect to an external monitor n check to see if it is the VC or LCD issue. thanks
I have the same problem, but was able to solve it by taking out the battery and use the ac adapter only. i think s10-2 has some kind of sleep/wake up problem thats related to the battery.
Posted on Mar 07, 2010
HI Jay: I just found I have the same problem,
power up, but no display. Tried the suggestion online to no avail.
How did you solve the problem.
Thanks
Peter
Posted on Jan 02, 2011
  • Peterw9664 Jan 02, 2011
    This is nuts; my S-10 is working A-ok now.
    I tried all the suggestion from above, NG.
    I left the power on for a while, turn the power on and off, try the QS button Wala !
    the display work.
  • 110 Answers
Connect a monitor to the Laptop and try fn + f7 key , if you are able to get the display in the connected monitor then u have to replace the LCD unit in the laptop which will be done by the service center
Posted on Nov 19, 2009
  • Lenovo Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.html http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
Cant get it to work with laptop
power ON your projector and laptop
connect your laptop and projector with VGA cable and press
if your laptop PANASONIC or NEC (Fn+F3)
ACER, HP,SHARP,TOSHIBA (Fn+F5)
LENOVO, SONY (Fn+F7)
DELL, EPSON (Fn+F8)
FUJITSU (Fn+F10)
APPLE (F7)
If problem exist remove the VGA driver in your laptop and reinstall the correct driver not a standard display driver
Feb 09, 2011 | Panasonic PT L720U Multimedia Projector
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to...
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Aug 25, 2010 | HP Pavilion M70 17" CRT Monitor
Transfer screen image to projector
Hi. Try pressing the Fn+F7 key to toggle the display option if you to use a projector or into your laptop itself or BOTH. Hope this Helps
May 04, 2010 | Lenovo ThinkPad T61 Notebook
Hi my lenovo s10 screen broken i want it to replace
You contract your service bandor in your area.Thay can help you.
Mar 11, 2010 | Lenovo IdeaPad S10-42312CU Notebook
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
I have a Lenovo T400, cannot switch to an external monitor with the Fn/F7, how do I fix this??
f7 key is not always fix in any laptop for switching to external monitor, if there is written lcd/crt on f7 key thats fine. if not try another key by pressing Fn.
if work fine . otherwise check with another unrepaired monitor. some time you can see display in monitor, but it may not work as an external monitor if repaired by local technician.
Aug 24, 2009 | Lenovo ThinkPad T400 PC Notebook
Getting the lenovo m500 dlp projector to work
Solved ....when it projects it says to push Fn and F7 simultaneously for Lenovo laptops. The symbol for the F7 on Lenovo is the computer screen and keyboard plus a screen with a line attaching. On the Toshiba it is the F5 key. Pressing the Fn and F5 keys on the Toshiba simultaneously gives 5 box choices, the middle is CRT and the correct one to transfer from computer screen to projector.
Jun 13, 2009 | Lenovo M500 DLP Projector
IBM Lenovo T60 connection to Samsumg 50'' TV using CGA cable
Try just pressing "Fn" and "F7" keys until the output switches to your TV.
Mar 23, 2009 | Lenovo Thinkpad T60 Notebook
Lenovo IdeaPad S10-1208Uw Netbook Logo
3,740 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
