Question about 2wire (1000-000057-000) Modem
No default gateway under ipconfig.....not connecting to internet...my freind let my use his internet connection for a while using wireless airlink device intill i got my internet back... now that i got it back it wont get a default gateway address...please help
  • 603 Answers
Is the internet light red or green? Green means the modem can get out to the net, red means it can't.
Also these 2wires have a know problem of the power adapter going bad, and looking like everything is fine.
Posted on Dec 07, 2009
Unable to access configuration utility webpage for an airlink 101 431w accesspoint.
Use an Ethernet cable to connect from one of the LAN ports on the router to the network port on your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG /RENEW
Press Enter
Look for output like: Default Gateway ... 192.168.1.234
Start Internet Explorer
Type http://192.168.1.234
Press Enter
Use the ID/password for the router to login to the router's web-interface.
Click to access the configuration wizards.
Jun 23, 2011 | Airlink 101 AP431W 108Mbps 802.11g...
My computer is showing the conection but not letting me on the internet how can i fix it?it says conneted and says no internet access.
1) try turning off and restarting the modem and router.
2) if you are using a dsl connection check if the modem is in bridge mode with your isp.
if yes then
type click on start->run->cmd and press enter
in the black window type ipconfig
now note the default gateway and type the default gateway in the internet explorer Eg \\192.168.1.1
check if the router is set to connection type as pppoe.
enter your usernaem and password and save the internet light will go on.
if the modem is not in bridge mode then try connecting you pc directly with the modem and check if the internet is working not not. if not contact your isp for settings.
if internet is working fine.
not connect your router to your modem and then your router to your computer.
check if the router is set to optain ip automatiicaly and save changes.
if you still face any issue let me know.
Jul 05, 2010 | Linksys Wireless-G Broadband Router
My netwrok consists of one laptop and one PC. the lap top can connect to the internet perfectly, the PC advises that it can connect to the access point, but not the internet
If you are trying to connect wirelessly to PC than check the ip address after it says connected. If the ip address is correct than try to ping the default gateway(To check the default gateway, Click Start-> Run-> ipconfig. You will get the default gateway), 4.2.2.2 and yahoo.com.
Let me know your findings.
**If this works please rate else let me know in case of further help.**
Jun 26, 2010 | Linksys Wireless-G WRT54GS Router...
Computer is picking up the wireless router but not letting me connect to it?
You will have to Increase the Channel Strength of the Router,
To open the EWS ( embedded web server or Router configuration page )
Open Internet Explorer and Enter the Default Gateway you find of Router without www. ( simply enter the ip like 192.168. as it shows with ipconfig )
you will get Default Gateway if you type IPCONFIG command under Dos command.
Once the Router page is opened, Under Wireless Settings you should be able to locate Channel Strength which at present must be at AUTO or 3, Set it to 11 and save the changes,
Try to connect again and it should work.
Jun 25, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
Aspire 5100 PC Notebook: How do i get my new Acer Laptop to connect to the ...
hi guest, welcome to the forum! Let me think why your laptop cannot access to internet during it's already connected to your router.
1) Because the connection is established --> Wireless is working properly
2) If you cannot access to Internet --> Access Restrictions is configured in Router.
How to configure?
1) Login to Router Administrator, you need to open a command line and use usage as ipconfig and you will see as the following
C:Documents and Settingssin.le>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.1.102
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Please open Internet Explorer with the address
http://Default Gateway ~ http://192.168.1.1
You need to know What is User name & Password to login, please configure "Access Restrictions" to allow access
I hope this is your case.
May 18, 2010 | Acer Aspire 5100 Notebook
Airlink ar430w not giving a network address to netgear wpn111
Try assigning the IP address manually. To do so go to Network Connections, right click on the wireless connection and click on Properties, select Internet Protocol TCP/IP and click on Properties again. Select use the following IP address and type the address of the same range as of your Router's IP. In case you do not know the range try 192.168.1.5 or 172.16.1.5 with the subnet mask as 255.255.255.0 for both, and when you use the IP as 192.168.1.5 use the default gateway as 192.168.1.1 and for 172.16.1.5 use the default gateway as 172.16.1.1 Also select the lower option as "Use following DNS Server address" and for 192.168.1.5 use 192.168.1.1 and for 172.168.1.5 use 172.16.1.1 .Click on Ok. Click on Ok again and now check for the connectivity.
Jul 08, 2009 | Airlink AR430W Wireless Router
My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Computers & Internet
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
My toshiba computer does not work with my wireless internet
what brand of wireless modem you have, what os are you using?did you switch on the wireless in your laptop? sometimes we overlook the most simple things, it happens to me..
ok, you have to configure your laptop to connect to your wireless modem, how? just connect first your laptop with wire to the wireless modem, does it work? if it does work you can take the default gateway ip add from your pc by typing IPCONFIG on the command prompt , then type it in your internet explorer address bar.
example default gateway..... 192.168.1.254
and supply the username and password, you can now configure your wireless connection wep/wpa configuration.
Apr 01, 2008 | Computers & Internet
2wire (1000-000057-000) Modem Logo
368 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
