Question about Cell Phones
Hello , The problem i am facing is that whenever i tried to connect my cell (5130c-2) its showing message on my cell memory card in use wait for sometime....and after sometime its not connected to my PC ......plz suggest some solution .
Which code can i use to unlock my nokia
Hello. You can get the accurate unlock code for your Nokia 5130c-2 from Unlock-Zone.com at an affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 5130c-2 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5130c-2.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5130c-2 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5130c-2 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5130c-2
SOURCE: MobileUnlockGuide.com
Aug 29, 2014 | Cell Phones
My nokia 5130c-2 is showing not enough phone memory!!! when i check how much memory i have left on the phone memory it show's less memory.Basically nokia 5130 have about 32MB memory but it shows about...
Did you save music files on phone memory? If yes , it is time to move it to your memory card. Also check for other big files that still keep in phone memory. If able , just move also your theme files to memory card. Move / delete also old messages files, games (if any), etc in phone memory.
Like computer, your phone need enough space for caching.
Hope this helps.
Regards
Oct 10, 2011 | Nokia 5130 Cellular Phone
Whenever i open an application...it says" not enough resources.close some applications and try again"..even when there is no application running.
Delete all the messags or format the cell udsing code
*2767*2878#, then it automatically restarts , wait for some time
May 21, 2010 | Samsung Jet S8000 Cell Phone
Delete the password from mmc 5130c-2
My nokia 5130c-2 memory card has a password which i cannot remembered. Can you please help me how to delete it without deleting my files inside that memory?
Dec 19, 2009 | Nokia 5130 Cellular Phone
My phone not connect by pc suit software
there are four solutions, 1-select offline mode
2-check the data cable 3-format your memory card(because there might be virous) 4-update your phone software using mobile internet
Aug 17, 2009 | Nokia 5130 Cellular Phone
Full phone memory even though its not full it affects the music library .my nokia 5130c phone shows that the phone memory is full but ithas much memory to messages and other files and even affects the...
please help me!!!!
my nokia 5130c-2 is showing not enough phone memory!!!
when i check how much memory i have left on the phone memory it show's less memory.Basically nokia 5130 have about 32MB memory but it shows about 6 To 7MB memory. All the files that i have recieved through bluetooth is stored in the memory card ...
whenever i change a theme the phone memory gets reduced...
i'm not able to update my music library because of this...
pz plz plz plz help me!!!!
Jul 02, 2009 | Nokia 5130 Cellular Phone
Full phone memory even though it's not full..
these problem needs a complete restore factory settings.i had these kind of prob with my 6085 phone and the phone memory corrupted..it occured when u removed ur mem card while using some files or application in it.
Jun 24, 2009 | Nokia 5130 Cellular Phone
I have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
Jun 11, 2009 | Nokia 5130 Cellular Phone
Transfer files into memory card
hello
for that you need to open message and then go to options nad over there you will find message setting
you have to change all incoming message come to you memory card not to your phone memory
May 25, 2009 | Nokia 3230
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
