Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
I am in Africa and the saw was shipped with little
I am in Africa and the worm drive saw was shipped with little oil. I cannot find the recommended oils here in Liberia. What can I use as a substitute?
    President:
  • 1,922 Answers
Drain out the remaining oil and if you can get just a clear mineral oil fine, otherwise standard gear oil would work also i.e. 80/90 weight
Posted on Nov 19, 2009
What kind of oil do I put in?
They sell tubes of oil for the saws. If you can't find it You can probably use 90weight gear oil. the stuff in the tube smells about the same.
Sep 05, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
I have a Skil worm drive saw and need to know what kind of oil to use.
This:
http://www.amazon.com/Bosch-80111-Worm-Drive-Saw/dp/B0002EVD9G
lp
Feb 05, 2011 | Garden
What kind of oil do i put in my skill saw 77
This saw requires Skil's heavy-duty, worm-drive oil, part number 80111. If you can find a local vendor that has some great otherwise, type 'skil 8011' in your search engine and shop around for an 8oz tube, they can run from $5 to $10 plus shipping.
Jan 28, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need to know what level oil in my skill saw mag77 should be?
have the saw as level as possible and put in oil until it starts to run out on the bottom of thread. Make sure you use a worm drive oil, just any oil will not work properly.
Mar 28, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I have an old Milwaukee 6378 worm drive saw (8.25") and it leaks a little on the front end. Not much but it is caked with oil soaked sawdust. I am going to change the gasket behind the red plastic "hood"....
If you put in the gasket (p/n43-44-0240) like you stated, and install a lock spindle service kit (pn14-46-1365) that should cure most or all of the leaks. The lock spindle kit comes with 2 o-rings and a new cap,one o-ring seals the cap and the other seals the pin. The only other thing that leaks once in a while is the armature seal (p/n45-06-0280) but to change it requires you to dismantle almost the entire saw, it you don't see any oil around the motor then its probably ok.
Jan 21, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
How much/what type of oil goes in my old wormdrive saw?
their owners manual doesn't give an exact quantity however they say to unplug the tool first then remove the fill plug and the lower plug and the oil should run out past the first thread. they recommend using their oil 80111 8 oz. tube however any good worm drive lubricant will work, Don't use anything like gear lube because the worm drive lube has an additive for anto foaming. Let me know if you need more assistance
Nov 18, 2009 | Saws
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Nov 17, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
What do I use for oil and how much should I have in my worm drive skil saw? I've had it for 5 years and never done anything to check the oil level.
just to the top of the filler hole no more than that, any oil will do,but lighter the better,,, if its not leaking it may not need any,,,rember the old saying,,,,,,,,,,,,
dont try fixing what not broken, or to put it another way,,, its serviced by disaster!!!
Oct 23, 2009 | Skil 7 - 1/4" 13 Amp Worm Drive Circular...
How much oil goes in a Makita Worm Drive Saw
I would call their tech line at 1-800-4625482. I looked at the breakdown and manual and couldnt find the information. If this doesn;t work let me know and I will call a rep and get the info.
Mar 03, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need to know how much oil goes into a skilsaw worm drive resvr.
Haven't heard anything so I checked the Milwaukee worm drive saw and they recomment about 1/2 oz. Make sure you use an oil for a worm drive that is not foaming. Hope this helps. Also when checking oir level have the shoe set for max depth and on a flat surface remove the oil plug, when filling tip the saw on its side and fill, turn back over and allow excess oil to run out if overfilled.
Jan 20, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
142 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
