Question about Digix DV-288P Portable DVD Player with Screen
How do I change the colors on my tv via the remote? I have an old TV and a satellite dish
    Problem Solver:
  • 9 Answers
Via the remote tv
click picture button or system button
or normal button
it depend on ur remote type
GOD BLESS U
Posted on Nov 19, 2009
Dish network remote turns tv on but wont change channels
1) clean the contacts batteries.
2) change by new batteries
3) resolder wires connectors batteries
4) Open the remote control, and clean the keypads very well with special spray contact R. Shack
5) Otherwise you must go to the repair shop TV, FOR Fix it
GOd bless you
Jun 18, 2012 | DISH Network Televison & Video
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
After setting up a new tv, the dish remote will not work with the satellite. what could be the problem?
mbpope
If I understand you correctly, once you installed your new TV, your DISH remote doesn't allow you to change satellite channels. If this is correct, you will need to readdress the remote to the receiver. I have provided a link with these instructions. Included with the link is instructions for programming the remote to your TV.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network
Nov 07, 2010 | DISH Network IR Remote Control
I programmed my dish network remote to turn my tv on and off,and after I programmed it I cant change the channels on the satellite it just controls the tv. The remote has a 21.0 on the back of it and my tv...
You need to try a different code,505,506,516,523,526,566,573,612,627,647,652,653,654,655,656,658,659,664,665,667,669,670,679,680,704,717,730,738.....hope this was helpful....
Apr 25, 2010 | DISH Network IR Remote Control
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
May 23, 2009 | Syntax Olevia 537H Television
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Digix DV-288P Portable DVD Player with Screen Logo
53 people viewed this question
Top Digix Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jerry Kramer
Jerry Kramer
Are you a Digix Televison and Video Expert? Answer questions, earn points and help others
