Question about ViewSonic VA703B LCD Monitor
The monitor will not display or power up. I've
The monitor will not display or power up. I've checked to make sure the monitor is plugged into the computer and the power cable is connected and plugged in. The screen just went blank while my son was working on the computer. Is a lamp out or is it a problem with the LCD graphic card or something else?
  • 11,361 Answers
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 19, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ViewSonic Master
  • 848 Answers
The monitor will not display or power up. I've? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
ILPI 023 490731400100R Viewsonic 790681400711R Power Supply Backlight...
Posted on Dec 18, 2014
Viewsonic VA1918wm-2 VS12085 intermitent display
If you have not updated the graph drivers, and it has been working, then you should contact View-sonic, go to their website, check warranty, but if you didn't change anything, it should be the monitor having problems. Did you check the plugs on the PC and monitor, the power plug on the monitor, make sure they are connected right and didn't come lose.
Mar 31, 2013 | Computers & Internet
I have a 40" screen colby flat screen, I'm having problems with my monitor coming back on???? I've tried leaving it unplugged for two days but when I plug the monitor up, don't nothing com
if the power indicator goes light green then turn to red, you must check the power supply board. look for a bulging capacitors.http://en.wikipedia.org/wiki/Capacitor_plague.a panasonic brand capacitors with low esr is a good replacement just look for the ratings and value must be the same when replacing. then make it sure check the polarity the positive and the negative. just let me know if you need further assistance good luck
Nov 01, 2012 | Computers & Internet
Dell laptop not detecting external display
Usually the external monitor and laptop screen toggles in one of three states.
LCD only
External monitor only
Both LCD and external monitor
Wait a couple of seconds between when you press Fn F8
This model laptop may not allow ectended display.
May 29, 2012 | Dell Latitude D830 Laptop Computer PC...
Hi! i am having problem with Display from motherboard. I had already checked ram, power supply but i didn't get any display. so how can i resolved this problem. Please help.....
I'm assuming this is a desktop motherboard? Make sure the plug for power is connected and tight. It is refuses to work see if you have another slot and try moving it to the free spot.
If it still doesn't work: 1. make sure your monitor is connected properly and turned on 2. if possible try the monitor on another machine to make sure it's not the monitor itself
If the monitor works correctly on something else and you've tried the above than it's likely that the video card itself died and needs replacing.
Aug 08, 2011 | Computers & Internet
My proline notebook is not displaying even when plugged in to an external Monitor.
When you plug in an external monitor, try to hit the combination Ctrt + F10 (or F7..depends on what key is designed for it. The key usually has a box picture on it) to make sure that you toggle displays between the laptop and the external monitor.
But if you've already done this but still didnt get any display, you can now go ahead and reinsert the memory module/s (RAM) of your laptop. A faulty or dirty memory module usually causes the unit not to POST (Power on self test). If you have 2 memory modules, try to gently clean the contacts using a pencil eraser and insert them one by one.
However, if this step will not resolve the issue, you need to consult help from an experienced technician. The video card of your computer is surely dead in this case.
Hope this helps.
May 27, 2011 | Computers & Internet
My motherboard have power but no display on display on monitor
Hi roystonfer33 ,
make sure the cable connected to your Monitor is securely connected and firmly in place. make sure the monitor is plugged into the power socket properly. if there is still no display, then maybe trying another cable for the display.
Mar 17, 2011 | Intel Motherboard
No display on moniter
Check the following if you don't see a green light on the monitor
1-Make sure Power cord of monitor is plugged to the wall outlet directly and the other end to the monitor (don't use a powerbar for this test)
2-Make sure monitor is turn on
If you see an amber light on:
1-Make sure the data cable is plugged-in snugly to the monitor and to the video card.
If after you have checked the previous steps you still have a blank screen:
1-Check the adjustments and color settings of monitor
2-Plug the monitor onto another computer to test it
If the monitor works onto another computer, check your video card.
May 03, 2009 | Computers & Internet
Apple monitor 20"
i’ve been repairing lcd monitor for awhile If you can or know someone that can take the monitor apart. check the power supply for caps that are bubbled there are bad. If you know how replace if not and know someone that does have them replaced. that should fix your problem the inverter circuit may or may not be on that power supply. if the two pair of lamp wires are plugged in then it all in one. replacing the caps work about 80% of the time. i would check and replace.
please let me know if this helps thank you.
Mar 29, 2009 | Apple Cinema Display Flat Panel Monitor...
Display problam
  1. Make sure that the monitor is turned on and has power. Make sure that the display's power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Check that all video cable connections to the computer video port and to the monitor are properly connected.
  3. Examine the pins on the video cable connector to make sure they are not bent or damaged in any way.
  4. Connect a known working display (if you have an extra one available). If you see video after doing so, replace your old display.
  5. Unplug the video cable and then turn on the monitor, check any message is showing in monitor if its shown means ur monitor is ok or else their is a problem in monitor..
  6. turn off the system and check the ram..
  7. Reset the computer...
Jan 28, 2009 | ASUS MB M3A78-EMH HDMI RT Motherboard
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
ViewSonic VA703B LCD Monitor Logo
347 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
