Question about Cell Phones
When it turns on it freezes after the windows screen, where the checkered t-mobile screen flows across
Picture parts
Flat panels tv's use memory to paint picture on the screen. If the chips are bad, you'll see lines, checkers etc.
Dec 30, 2013 | Emerson Televison & Video
Computer freezes frequently and has to be shut down. Then there is trouble booting back up, sometimes have to shut down and turn back on multiple times before getting windows screen. have tried...
Probably a hardware problem, e.g., "flaky" motherboard, or "bad" RAM, or a "dying" hard-drive.
Consider temporarily swapping-in a different disk-drive, and install Windows onto it,
to see if changing the disk-drive cures the problem.
Or, search online for 'MEMTEST86+', download the 'ISO' file, and burn the ISO file to a create a bootable CD-R disk. Boot from the disk, to run the RAM-checker.
Nov 05, 2010 | HP Compaq nc6220 Notebook
SCREEN FREEZE-CHECKER BOX
reboot your computer and during starting type f 8 keys then start in vga enable mood then setup vga 1024 .
May 16, 2009 | Gateway FX7026 PC Desktop
XBox 360 freezes and gets red checkered screen
make sure the display adapters are properly plugged in and that you have the switch set to either hd or tv on the back of the xbox....also make sure the connection from the rca's to the tv are secure
Apr 25, 2009 | Microsoft Xbox 360 Console
Dash Phone freezing up in the WHITE SCREEN
This may work for you
Will it just not boot up all the way but just stops?
If so try the procedure at this link: T-mobile Dash Master Reset
If this doesn’t work then proceed to the following guide below.
The Windows Mobile installation may be corrupted.
The only way to fix that problem is by re-installing the windows software on the phone.
from: http://www.howtofixmyphone.com/how-to-stop-t-mobile-dash-from-rebooting-over-and-over/82/
Dec 07, 2008 | T-Mobile Dash Smartphone
.the mouse moves randomly across
If mouse is moving randomly across the screen then you may have to change the mouse or the mouse pad. If system freezes automatically that is your software problem. Please install a fresh copy of windows xp or vista whatever. Hopefully it should work . thank you.......
Sep 12, 2008 | Computers & Internet
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Freezing with a blue or checkered screen
try holding the reset button on the back in for 30 seconds.    Sounds like its in test or programming mode.
Jun 13, 2007 | Magellan Roadmate 760 GPS Receiver
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
