Question about LG RM-32LZ50 LCD TV
Damaged Motherboard. My LG LCD RM-32LZ50 stopped working. I took it to the service and they told me that the motherboard is damaged. They don't have the replacement part. They told me that if I could buy the part, they will replace it. Is it possible to find the motherboard of that LCD, if so where?? Thanks, Andreina
  • 530 Answers
I'm assuming they intend to replace the entire circuit board. The only place you are going to get the entire board is from LG or an LG certified repair center.
You do have another option however. Although repairing individual components on circuit boards is not for the faint of heart, it can be done. If it is minor for instance a break somewhere along the tracings it can be done a lot cheaper then replacing the entire board. The hard part is locating one in your area.
In any event I tried to include all the possible links that you can try for assistance.
The first link is probably what you need. It has a listing of all the parts for the RM-32LZ50 that are available . You will need to identify circuit board (pcb) that needs replacing. There is a total of 5 pcbs. The cost of these are $10.24, $13.26, $15.77, $22.27, $160.05.
The second link is the same site, just the home page so if you have any trouble with the first link use the second one. Click on the "Shop" button the right hand side then input your model#RM-32LZ50.
The third link is self explanatory.
Hope this helps.
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEARCH&mrpn=ZENRM30LZ50&model.variation=
http://www.encompassparts.com/lgconsumer/
Independent LG Repair Providers:
http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
Posted on Nov 19, 2009
On start up my lg x120, (s/n: 003msfb0044355)" displays operating system not found" it wont go any further.What do i need to do?
This type of message indicates that the BIOS is unable to detect an operating system. What may cause this condition can be a loose hard drive, a bad data cable, bad hard drive, bad motherboard storage controller, malware, virus, or incorrect BIOS setting.
To troubleshoot, start by entering the BIOS and see if the BIOS detects your hard drive. If it is detected then make sure it is set as the 1st boot priority item. If it is not detected, then open up your laptop to inspect the wiring of the hard drive. Make sure it is firmly seated into the motherboard connector (Don't forget to have the laptop/pc powered off before opening the machine).
Next, remove the hard drive from the laptop and connect it to a motherboard from a desktop to see if it spins and loads the operating system. If it does work, then the hard drive is ok and the motherboard on the laptop is damaged.
You can also use a functional hard drive to install on the pc/laptop to rule out a bad motherboard.
If all of these don't work, you will need to reinstall your operating system because malware has damaged your operating system.
Aug 28, 2011 | Computers & Internet
How do you get a touch screen to work the phone is working but the touch screen isnt
LG has released a line of cellular phones that come equipped with a sleek touch-screen LCD display. Since these screens are high-tech and sensitive, they can be prone to damage or scratches. If the touch screen on your LG is damaged, and you don't have the money to take the device to a service technician, you can open up the phone and replace the touch screen yourself.
1. Turn off your LG and slide the back battery door down and off of the device. Lift the battery out of its compartment and use your Phillips screwdriver to remove the four screws located on each corner of the compartment.
2. Use your fingers to remove the back panel from the phone. The green motherboard will be revealed underneath.
3. Unplug the four ribbon cables that connect at the middle of the motherboard. Unplug the antenna cable in the top-right corner of the board. Lift the motherboard out of the phone housing and set it aside.
4. Use your Phillips screwdriver to remove the two screws located at the top of the phone housing, then separate the back frame from the front housing of the phone.
5. Lift the damaged LCD screen out of the phone housing. Replace it with a brand-new LCD screen (available from your LG retailer or online) and reassemble your phone in the reverse order you took it apart.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | LG Vu CU920 Cellular Phone
My lg screen RZ 32LZ50, RZ-32L750.AKPIWUA cracked on flight where can i get a replacement.
Hello
Contact your nearest LG authorised service center. They only can provide it to you. They won't give it to you, but will get the set repaired with new screen at their service center. OL.
Apr 28, 2011 | LG RZ32LZ50 32 in. LCD Television
No Picture but has sound, picture comes up small pixels then fades out
You have a weak power supply,replace the bad electrolytic caps,or replace power supply.
Dec 27, 2010 | LG RM-32LZ50 LCD TV
The hp pavilion dv2000 not booting
You might be still covered under extended warranty, check here
Jul 27, 2009 | HP Pavilion dv2000 Series Laptop Full...
Is my LG 32lz50 tv hd and digital
Your tv is HDTV ready but unfortunatly it only has a NTSC tuner which is analog, you will need a set top box to recieve OTA over the air digital, if you have cable sattilite or an HD dvd player you can display HD. You only need the set top box if you use an anttenna. Let me know if I can assist further and please rate this solution. lone99star
Jan 11, 2009 | LG RZ32LZ50 32 in. LCD Television
Sony pcg 9h4l motherboard issue
Try to power off unit and remove the battery. Then press and hold power button for 30seconds.Put the battery back and turn it on. If it turns on turn it back off again and remove the battery. Connect your VAIO using the AC adapter only. If this will not resolve your issue you can check this with SONY or any certified service center.
May 23, 2008 | Sony MBX-49 ASSY Motherboard
LG RM-32LZ50 LCD TV Logo
716 people viewed this question
Computer Repairing
Computer Repairing
