Question about Cell Phones
How tofix my samsung ...the slider - Cell Phones
Network lock
Hi. you can get the network unlock code for a Samsung E2550 from Mobile-Unlocker.com at affordable cost.
..........UNLOCKING INSTRUCTIONS..........
Method 1:
1 - Switch ON your Samsung E2550 Monte Slider with a NOT ACCEPTED SIM Card.
2 - Samsung E2550 Monte Slider will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung E2550 Monte Slider shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung E2550 Monte Slider.
3 - Compose : #0111*CODE#.
Jul 07, 2014 | Samsung GT-E2550 Cell Phone
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
J700 camera could not start if Slider already opened error comes "Open Slider"
There is an switch provided near the slider so that when you open it it activates and you can use the camera function.
When you open the slider if it doesnt activates the switch then you cannot use your camera.And it shows as 'open slider'
Please take your mobile phone to service centre they will fix this problem.
Its a very small problem
Thanx
Jul 26, 2010 | Samsung J700 Cellular Phone
I have a samsung SGH - J600 and the touch sensitive buttons were working untill half an hour ago. Is there anyway to fix the problem
j600 samsung has slider belt called ribben problem when ribben got damage then it stop working the ribben ( slider belt ) connect the internal connection. try to contact nearest service provider.
Mar 31, 2010 | Samsung SGH-J600 Cellular Phone
MY SAMSUNG PHONE TURNS OFF AND TURNS BACK ON BUT NOT ALL THE WAY. I NEED HELP!!!! WHAT WRONG WITH IT??
it happens with samsung sliders phone. because sliders phone always connected via only thinn ribben. which is connect the screen and mother board. when the ribben gone damage then samsung phone do thins things that turn on and turn off itself. if your phone is slider samsung G600,U600,J600 and j700 then it could be the ribben problem.
Dec 30, 2009 | Cell Phones
The keys on the slider don't work properly. I press them but nothing happens. So the arrow keys and two side buttons (call and hangup) don't work. Also, when I slide the phone shut, the white lights on the...
it is the slider problem which is called ribben problem. u 600 phone is so thinn and samsung they putted so thinn ribben in that it goas damage so quickly. try to change slider or ribben.
Dec 30, 2009 | Samsung SGH-U600 Cellular Phone
Samsung Gravity T459 phone. Slider spring popped out of position, how do I get it back into proper location?
Nov 24, 2009 | Samsung Gravity SGH-T459 Cell Phone
User manual for samsung s3500 slider phone
http://downloadcenter.samsung.com/content/UM/200904/20090406191043562/Samsung_S3500_UM_EU_Eng_Rev[1][1].1.1_090203.pdf
Jul 25, 2009 | Samsung Cell Phones
U600 dropped and in half :S
Simple . . . buy a new phone.
Jul 02, 2008 | Samsung SGH-U600
go to settings and on slide settings
Apr 23, 2008 | Samsung SGH-D600 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
