Question about IBM ThinkPad T23 2647 Notebook
T23 wont boot
I have an IBM Thinkpad T23, when i hit th power butting the battery and power symbol turn green, nothing shows up on screen, and the fan runs fast then slow the whole time, what should i do. I just replaced the motherboard.
  • 2 more comments
  • Anonymous Feb 29, 2008
    Thank you!  My daughter used the T23 on batteries, closed the lid, and weeks later I found in under her desk!  It should no signs of life not even when plugged into AC.  Did the usual stuff, remove batteries and power cord, let it sit for a while, pressed the power button, reinstalled the batteries and nothing.  Then I found and read this post and did the following:
    Unplugged power cord, removed both batteries, removed memory, plugged the AC back into the unit, pressed the power button and presto!  I sprung to life.  Shut it down, reinstalled the memory, the Li-ion slot load battery, powered back, and still good.  Installed the main battery, removed the slot load battery, still good.
    I'm happy, and my daughter is out of the dog house!  Thank you.  Adam
  • pcharm129 Mar 04, 2008
    When I hit the power button the battery and power symbol turn green, nothing shows up on screen, and the fan runs. I tried booting from the disc drive using 2 different hard drive formatting discs and a Windows OS disc. Nothing. Will try the other steps I just read on this thread and keep my fingers crossed.
  • Luing Apr 06, 2008
    same problem. how do i test if it is a hard drive or motherboard problem?
  • Anonymous May 16, 2008
    Had the same problem; tech said it is motherboard; bought a motherboard on ebay, took to the tech. He fixed it (total cost part $65 labot $130) said it worked; brought home - no life. Tech tested again and said the motherboard was faulty; contacted ebay vendor who was kind enough to replace it with another one. Took to the tech - the machine would boot, but does not recognize the hard disk. Tech says (after several hours and trying changing the processor) the second motherboard is also faulty. Hard to believe! Do not know what to do?
Your t23 has lose parts that need either resoldered or replaced.
you will need to send it to a repair service which is very pricey or replace with another one. new around 199 us dollars or more, or used 70 us dollars at ebay.
I will buy your t23 if you are looking to get rid of it. it has a faulty mother/mainboard with bad solder points. i need the thing for the ic components to repair other t23
contact me at ddarr@verizon.net1 delete the 1 of the end
Posted on May 11, 2008
Having same issue. how much memory (ram) do you have installed. this model t23 (2647) can only have 256MB DIMM per slot - total 512MB (although it can handle 2X512MB DIMM's) i'd try booting with only 1 256MB DIMM and if sucessful had the other.
Posted on Apr 13, 2008
  • 788 Answers
I would unplug it and remove the battery. Plug it back in and try without battery, if it still doesn't work, unplug the power again and remove the memory (RAM). Plug it back in and try again without RAM, if it beeps then the motherboard is probably good. If you had more than one piece of RAM, try one at a time and see if you get it to boot with one of them.
Posted on Jan 11, 2008
In my IBM T23 Thinkpad battery is fully charged showing green light constantly but not able to switch 'ON' after pressing the power button. What should I do?
try to switch it on with power cord still plug in it, if it do boot-up, you have to replace your baterry, if not somethings wrong with your laptop
May 06, 2010 | IBM ThinkPad T23 2647 Notebook
Ibm thinkpad t23, will not come out of sleep mode even when manually turned off and on. Cooling fan comes on, only blank screen.. I have removed battery and let it sit for a while, and then restarted it,...
Please press F8 at boot up and boot in safe mode. Restore to a previous date given in bold numerals.
Alternatively, after F8 select Last Good Boot up.
Mar 16, 2010 | IBM ThinkPad T23 2647 Notebook
ThinkPad T23 white screen
1. your issue may be a bad hard, a damaged or loose flex cable to the LCD screen, a defective CPU (central processing unit, a cmos battery that needs replacement ( this is the battery that retains the information for the motherboard), a bad power supply regulator on the mother board.
2. this is just a few of the issue that have caused a white screen.
3. Laptops are mostly disposable and are usually good for 2to 3 years of service depending on the care taken.
Your friend probably thought he was helping by giving this to you to see if you could use it or part it out.
Not worth the work unless you are into PC repair or project work.
Mar 03, 2010 | IBM ThinkPad T23 2647 Notebook
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
T23 Thinkpad turns off during boot after restart
My guess would be ;-
A power supply problem with the battery and/or power adapter
The most likely one.
The CPU is overheating and shutting down and if you wait a while and it will power it up again, it will then run for a while and shut down again.
This can be caused by a faulty fan (its not spinning and needs to be replaced) or the vents are clogged with dust (needs to be cleaned and you may need to remove the fan assembly to do this).
Jan 27, 2009 | IBM ThinkPad T23 2647 Notebook
IBM Thinkpad T23 Won't Start
do you have a hard drive install??
laptop need a hard drive to start up. the one time start up you see before is just a accident.
as far as battery not charge, that is the porblem you run into, when you get laptop from ebay (taking chance).
you also need to download all of the drivers from IBM for the laptop.
Dec 10, 2008 | IBM ThinkPad T23 2647 Notebook
T23 fan error
This is a commin IBM issue fans going Bad ... to try and free it if it's just dust you can actually blow into the vent with compressed air and free up the Fan ... The IBM T series all check fan before powering up.
The replacement is not too difficult to do.
The safest air is the can type to blow in there.
Good Luck
Oct 29, 2008 | IBM ThinkPad T23 2647 Notebook
No visual display
Function F7 will enable the external video monitor connection and will toggle between the screen, the screen plus external monitor, and the external monitor only. Try hitting function F7 and see if that helps. Also there is a small switch that is activated when you close hte lid to turn off the display when the lid is closed. make sure that this little switch is not stuck.
Mar 21, 2008 | IBM ThinkPad T23 2647 Notebook
T23 - Ready for the Graveyard?
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Nov 13, 2007 | IBM ThinkPad T23 2647 Notebook
Does'nt come on at all
Can you access the bios? If you are able to get a bios screen, the problem is not the processor unless it's overheating really fast. See if the vent for the fan is clogged with dust/hair/etc. Also, the memory is a possibility. Instead of swapping it out tho, just put pressure on it in such a way that it's pushed down on the motherboard. These ram slots are known problems. Try it, you may be surprised. Good luck
Oct 08, 2007 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
374 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
