Mounting brackets for cd-rom drive
I need the mounting brackets for NEC Tower cd-rom drive slot. I have searched and can't find anywhere that sell them or has them. Can you help me.
  • 56 Answers
I can help you. I have a friend name nile he has a busines of this mail him nile0007@rediffmail.com he will help you.
Posted on Feb 13, 2008
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
How to put dvd/cd tray back in on dell tower
youll need to mount the drive in a bay slot in the front of the tower, then reinstall the screws or clips and reconnect the ide/sata cable and the power cable. thats all
Mar 23, 2010 | Dell Computers & Internet
Need driver for NEC 271 ROM as used in Pac Bell PC running WIN 95
try this site and see if you get any joy
http://www.cnet.com.
type your rom into the search engine
Oct 12, 2009 | NEC CDR-271 (cdr271) 4x CD-ROM Drive
My desktop is not playing cd or dvd's.
go to control panel and search for new hardware...or download new firmware fpr your device
Sep 29, 2009 | NEC ND-3550A DVD±RW Dual Layer Burner
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Reading CD or DVD are uncertain.
hi... you need to set on bios as 1st drive/boot is CD/DVD rom player or HDD0,HDD1 or HDD2 to the 1st boot/drive..Thanks...Good Luck..^_^
May 12, 2009 | NEC Computers & Internet
Gateway M505 internal cd-rom slot does not take in a cd dvd
Not unless you know A LOT about electronics. It's best to just remove the drive and buy a replacement on ebay.
You can either search for M505 drive
or use the part numbers from the drive if you want an exact replacement.
Best of luck!
Feb 25, 2009 | Gateway M505 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
