Hitachi External Hard Disk Dirve not functioning
I purchased Hitachi External Hard Disk Dirve on my last trip to the US. The details of the Hard Disk are as mentioned below : Serial No. : S/N : CEGAKEDF
Model : SIMPLE TOUCH BY HITACHI
320 GB
ST/320GB-CL
96202-00320-007
The Hard Disk is not functioning. Request if you could kindly let me know if i could have a replacement or will i get a rebate.
my email id is : pamela.castelino@nex-sales.com
Thanks & Regards
Pamela
  • 134 Answers
Well do you have the receipt of the Hard Drive? and does it cover the warranty period? if it does, go send the device back to the store where you've purchased it and have a replacement or refund.
Posted on Nov 19, 2009
I have one hitachi deskstar 1 tb hdd it has important data, and its not detecting is there any way i can get back those data. please hepl
There are some tests that can help you determine the gravity of the problem, or at least the cost of getting the data back.
- First, try on an other computer where you are sure that the USB ports are correctly working.
- An other option is to try on the same computer but with an other USB disk.
If nothing happen, this is likely that either
1. The USB adapter or the power supply from the external drive is dead.
2. The electronic part of the disk is dead.
3. The mechanical part of the disk is dead.
To eliminate the reason 1 from being the problem, remove the disk from the box, this is probably an SATA disk or eventually an IDE disk. You can connect the disk directly in your computer, or if you're not comfortable with that, you can buy an external adapter like this one :
http://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B001OORMVQ/ref=sr_1_2?ie=UTF8&qid=1310226408&sr=8-2
You can also check if you hear the disk spinning up when you power the box in a silent room. This is likely to eliminate the reason nr 3.
If only the reason nr 2 remains, you can try to find on ebay or other online reseller the EXACT same model of disk by looking the product nr and/or model nr on the disk itself, and replace the electronic board. ( there are some small torx screws and connectors... should be easy.) This should cost you between 100€ and 200€.
The very last chance, also the most expensive, is to contact a specialized hard disk recovery service. This is the easiest as they will do the same procedure as described, but they will go far more in detail, and could go up to replace mechanical parts.. You must count between 400€ and 800€ to get back your data.
Hope it's clear.
Regards,
Fran?ois.
Jul 09, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My pc and Imac can't detect my hitachi Neso N2501s.1 external hard disk, the light on the hard disk is on and the fan is running but they can't detect i've even try it on other pc but no...
there something wrong with hitachi neso cord, the one you used to connect from hitachi neso to your pc or imac, try to purchase new cord.
Jun 22, 2011 | Computers & Internet
I have purchased the lenova laptop in which th Hard Disk is from Hitachi and my data is in the Hard Disk how can i get back my data
You can use an external Hard disk and transfer your data.
If you want to transfer it exactly as it is, U can remove the Hitachi Hard Disk, put it in a hard Disk case, and use it as an external hard disk
Mar 01, 2011 | Computers & Internet
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
It beeps and computer does not reconise it
Check the warranty-status. If the warranty still is valid, then Hitachi will replace the disk-drive, at minimal cost to you.
If not, then disassemble the enclosure, remove the old disk-drive, buy a new compatible disk-drive, and connect it, to "reconstitute" your external storage-device.
Oct 28, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
My 120 Hitachi hard drive is not detecting any more
All I can think of is to completely remove all ya USB layer, via Device manager, uninstall & remove drivers on everything USB, then reboot, and then after try to plug ya drive in again BUT after it finishes re-installing the USB layer give it 5 mins or so...then do so. GL
Jan 26, 2010 | Computers & Internet
Hitachi 80 GB. USB HDD problam.
If you plug it in and it does not appear, it may be choosing the wrong drive letter.
If that drive letter is already in use it will not appear.
Open the start menu, right click on my computer, then choose manage.
Select (on the left) Disk Management.
If it appears in there.
Find the thumbdrive in the list and right-click and choose 'Assign a new drive letter' . Make it like M or somthing far down in the alphabet.
If that does not appear under the disk management then the disk might be physically damaged.
An urban myth (which does sometimes work) includes putting the drive in the freezer for a day or so.
Also remember it might be somthing as simple as a bad cable or port on the computer. Try to access it with a new cable from a diffrent computer.
Apr 23, 2009 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 27, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Hard Disk Replacement
Hi, google Hitachi - the info you require is on their website.
Jul 20, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Computers & Internet Logo
450 people viewed this question
David Payne
David Payne
