Question about LG VX5500 Cell Phone
My phone seams to be stuck in a headset mode, only allowing me to hear and be heard on calls when i have a headset in. I tried resetting it to factory, however problem persister. Any suggestions?
Stuck on Headset User profile
go check out your post on the net 10 forums. You just got a reply...
Nov 30, 2013 | Motorola Mobility W409G Prepaid Phone
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
LG VX5400 Cannot hear during calls
I was able to get the phone "unstuck" from this mode by plugging and unplugging my wired headset several times. Perhpas the contacts were dirty inside the jack...
Sep 20, 2009 | LG VX5400 Cellular Phone
Headset issue
It should be in your BT devices, open it, and search for the headset, click disconnect. Also you can turn off the BT.
Sep 05, 2009 | Cell Phones
During a call I can hear the person on the other end, but they can not hear me.
possibly the mic is broken, try recording yourself on ur fone with voice recorder, if it wont record like that then its ur mic x
May 07, 2009 | Sony Ericsson Z750a Cellular Phone
My Samsung Instinct is stuck in headset mode
DONT DO THE RESTART/ERASE CODE!!!!!!!!!!! its a hardware problem, not software or virus. your phone is probabluy stuck in headset mode, where you can hear the ringtone for incoming calls and alarms but not calls (without headphones). you three real options are to (1) stick a boby pin or stylus into the jack until it leaves headset mode (2) more invasively, find a really small screw driver and open the phone(screws are under the battery cover, in the corners) and poke in the earphone jack or (3) get a new phone. thats all i can tell you.
May 05, 2009 | Samsung Instinct Cell Phone
LG shine stuck on headset mode
reset the phone or cntuck to lg care
Apr 10, 2009 | LG Shine KE970 Cellular Phone
W580i stuck in headset mode
reset the phone settings but doing this ur phone memory will be erased u need to have aback up
Feb 15, 2009 | Sony Ericsson w580i Cellular Phone
Pairing motorola hs810 with sony ericsson k800i
unless it is a stereo bt haeadset is the only way you would hear a mp3......
Aug 18, 2008 | Sony Ericsson K800i Cellular Phone
LG VX5500 Cell Phone Logo
286 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
