Question about ASUS A3H Notebook
Wireless cards is it built in - ASUS A3H Notebook
If you are referring to the notebook having wireless connectivity (being able to connect to the internet via your wireless modem) then YES!
It comes with the Intel High Definition audio modem and 10/100 Base T PCI LAN on board, which will allow you to connect to the internet. You can also use the RJ45 plug to connect to your modem with an ethernet cable.
Posted on Nov 19, 2009
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
I have ibm t20 2647 laptop i just install new window and i couldnt find wireless option now ?
Most T20 models did not have wireless built into the computers by default. You may have to add a wireless adapter to your computer. To verify whether or not you have a wireless card, open the middle cover on the back of your computer (with the computer unplugged and the battery removed) ... you should see a small card about the size of a business card next to an even smaller card. If the larger card has two antennae wires connected to it, you have wireless. If not, you don't have built in wireless and will have to use a USB or PC Card adapter.
Sep 06, 2011 | IBM ThinkPad T23 2647 Notebook
Where is the wireless card found in the dell lap top
Two possibilities:
1. the laptop has _NO_ built-in wireless capabilities -- you have to insert either a USB wireless-adapter or a PCMCIA wireless-adapter;
2. the laptop _DOES_ have built-in wireless capabilities, and the "mini-PCI" wireless card is somewhere underneath one of the "access" doors on the bottom of the laptop, or somewhere "under" the keyboard.
If it's there, leave it there -- don't try to remove it, unless you KNOW what you are doing!
Nov 16, 2009 | Dell (8U082) Wireless Adapter
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
Laptop states wireless adapter not installed and configured? worked before.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Wireless without a cable
Some T40 series (especially T42) laptops have built-in wireless cards and you only need to install the wireless driver.
If you don't have a built in wireless card you can purch a PCMCIA wireless card and inset it into the PCMCIA slot on the laptop.
These cards are common and are available from several manufactories such as Netgear and DLink.
Mar 29, 2009 | IBM ThinkPad T40 2373 Notebook
Linksys wireless notebook adapter 2.4 GHz??
Since your Toshiba has a wireless card built in, you wont derive much benefit from using it.
It is basically there for people who don't have built in wireless cards.
Jan 19, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless card
could you tell me if the onboard built in wireless on this laptop is working or not?, as it is built in and the wireless card will be conflicting, hense very slow and the pc not seeing the card as the main wireless connection and not booting up until removal of the card
Aug 14, 2008 | Acer Aspire 5050-3242 Notebook
Wireless
Roy:
Seems like you are installing LAN driver but want to enable Wireless NIC? In order for your Wireless built in card to work you must look for wireless NIC card drivers. Also make sure once you install wireless driver go into device manager and look for your wireless card. Is there a sign of exclamation or cross over it, is any problem with it?. Check if the wirless card is disabled, go into start, connect to, show all connections, right click over your wireless card, properties, configure, check if the card Radio is ON or OFF. Let me know please.
Thanks.
Dec 15, 2007 | Computers & Internet
ASUS A3H Notebook Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
