Question about Sentry Fireproof Safe
I have the combination for my mtc safe though i do not know the order in wich i am suposed to turn the dial
4 Suggested Answers
joboo1
  • 257 Answers
SOURCE: get new combo on senry dial safe
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Posted on Feb 14, 2009
  • 34 Answers
SOURCE: opening problems
Right 3, Left 2, Right 1.
Posted on Apr 30, 2009
  • 155 Answers
SOURCE: My Sentry safe MS0100 combination dial will not
If the safe is brand new.. you must first remove the locking screw at the base of the combination lock dial lockcase.. discard the screw.. Make sure you have the owners manual with the sticker and default lock code nearby before locking the safe.
The factory has a preset combination code that cannot be deleted. It is on the owners manual. You can use that code if your codes have become compromised.
Also ensure the batteries are fresh. This may also be the problem.
Anything beyond this will require assistance from Sentry. Your serial number is on the side of the door. Have that ready.
www.sentrysafe.com
Best of Luck
Posted on Apr 18, 2011
I forgot yo open a security box. Please let me know how.
1 You will need to find out the combination. The first thing to do is to move the entire dial that is in the lock to the right. This will let you know that all the wheels are disengaged. 3. You will need a stethoscope. Each time you turn the dial, you reach the point of the combination number you can hear a click here. You should make notes considering the numbers you can read on the dial each time you hear two clicks. This will help you know the length of the combination. You must use a stethoscope to listen carefully and precisely where the clicks sound. 4. Repeat the process. Then repeat the process considering the number of clicks you hear in the process, repeat several times to make sure you're right about the number of click. This information should be represented in a chart in order to know the numbers of the combination to open safe. You have to start testing the clicks generated by the box when the dial is turned, the dial should be at zero.
5. Combine data to open safe. With the data obtained when listening to the clicks generated by the dial, you should start making combinations and test them in the safe until you get the perfect combination that will help you open the safe. Example if when turning the dial you could hear 3 times two clicks, ie the combination of the safe must have 3 numbers. Consider the exact numbers you could see on the dial when you heard the clicks. Then you must have something like this in your notes (2, 65, 34). Start combining them and try in the safe until you find the right combination, start making patterns and discard. Then those copied in your notes will be the secret code numbers that will open safe. It is very important that you have been very careful when listening to the clicks and that this process has been done several times to be sure that these numbers are correct. Now you can make patterns, considering the numbers that you raise in the example, such as: 2.34,65); (34,265); (65,2,34) and so on until finding the correct one. That is why you need to write down all possible combinations and tosa trials. Remember the success of, without opening your safe, without a locksmith, and also considering that you do not have the possibility to call a manufacturer. Be: • Listen carefully to the sounds of the clicks you hear in the safe. • Avoid other sounds that may distort your ability to listen carefully • Record exact numbers where you clicked • Be patient and test your combinations. You must have on hand the instructions of the manufacturer of the safe, if you do not have it, look on the web since surely the manufacturer has a page where you can find this information. You could also call the manufacturer and prior identification will give you the key to your safe. Otherwise and if you've tried all the possible combinations and you just can not do it, call a locksmith. You no longer have a bad life and recover your valuable items, open safe can generate waste of time but if you strive you will stay with great satisfaction.
Aug 13, 2017 | Cell Phones
Can u assist me with opening my safe
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Nov 04, 2014 | Sentry Fireproof Safe
I have the combination, but I forgot the order that it is supposed to be applied. IE do I start by turning left or right? How many times? then for the next number in the oposite direction, how many...
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes
31-10-31
  1. Turn the dial to zero.
  2. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  3. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  4. Turn the dial to the left to the last number (stop the first time on your last number).
  5. Insert the key; turn right.
  6. Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes
31-10-31
  5. Pull the handle down; the door should open.
Electronic Locks
31-10-31
  1. Insert the tubular key into the lock to the left of the key pad.
  2. Turn the key all the way to the right until the plunger pops out.
  3. Press the five-digit factory code. The green Proceed light will come on.
  4. Pull the handle down; the door should open.
4 Digit Combination Lock
31-10-31-10
  2. Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
  3. Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
  4. Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
  5. Turn the dial to the right to the last number (stop the first time on your last number).
  6. Pull the handle down; the door should open.
You can find more information about your Sentry Safe at www.SentrySafeShop.com
Dec 11, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
How do i unlock my safe with: Model number MSW 3110 Serial Number BK 706346 Dial Combination 23-93-59 Thank you. Dan.
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
Dec 01, 2010 | Safe International SentrySafe Home/Office...
I know the combination of sentry 1610 safe but can not open.
Are you sure that you are turning the dial correctly? 3 Digit Combination Lock
31-10-31
31-10-31
31-10-31
Electronic Locks
31-10-31
31-10-31-10
Nov 21, 2010 | Sentry Fireproof Safe
How do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Insert your sentry safe key and turn it until the plunger pops out.
Pull the handle down; cracking the Fireproof Sentry Safe open.
Jun 06, 2010 | Sentry Fireproof Safe
NEED TO OPEN A SENTRY SAFE BUT DON'T KNOW WHICH WAY TO TURN AND HOW MANY REVOLUTIONS PAST NUMBERS SHOULD BE USED. i HAVE A OLDER SENTRY VALUE GUARD SAFE, MODEL # 1330
Locksmiths advise If your safe doesn't have a key, skip Step 3.
Pull the handle down; cracking sentry safe open.
Sep 13, 2009 | Sentry Fireproof Safe
Brinks fire resistant safe model 5059 instruction manual
Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Apr 30, 2009 | Computers & Internet
Know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Feb 28, 2009 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
213 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
