Question about Brother MFC-3220C Plain Paper Inkjet Fax
M3220C Fax Hi, I want to reconfigure this machine to a new fax number and change details? I'm really looking for the manual?? Can you help?
    Genius:
  • 1,226 Answers
You can find manual here: http://www.brother-usa.com/downloads/Default.aspx
good luck!
Posted on Jan 11, 2008
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Resetting fax name and number
GO MENU, INITIAL SETUP ,THERE U CAN FIND
May 26, 2010 | Brother 2440C Colour Plain Paper Inkjet...
Toshiba estudio16s need to change fax# inside machine
You have to change your OWN ID (fax) number through the menus.
Aug 03, 2009 | Office Equipment & Supplies
Printing wrong fax number on paper headings
HI
Cant find a manual for that model but this is close enough for changing the details i think.
Download it from here
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IMAGERUNNER%202025I-_E
Feb 16, 2009 | Canon imageRUNNER 3035 Black and White...
Fax number change
Hi ajames - I could tell you how to do it but it would probably be easier acd less confusing if you looked at the manual. Below is a link for your manual. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_775_EN_86.PDF
Jeff
May 18, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Pana fax uf 8000
I'm not sure which key is used on that model but look for a key that says one of these: menu/user settings/reports/program.
what you are really trying to do is get to your reports programming section, then select tx report, then choose print tx report and will fix your problem, you may want to change you fax number if that number changed also.
mikey
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
BROTHERINTELLIFAX775
TO NO MANUAL,
WHEN YOU DIAL A FAX NUMBER, AND IF YOU
HAVE DIALED IT CORRECT, YOU NEED TO
WAIT UNTIL YOU HEAR A COUPLE OR A FEW
DIFFERENT "CONNECTION" SOUNDS, AND
THE LAST SOUND IS THE FAX IS CONNECTED
TO THE FAX NUMBER DIALED SOUND.
IF I AM CORRECT, THE FIRST SOUND IS
A LOW TWEET LIKE SOUND, THE SECOND
SOUND IS A HIGH PITCH TWEET SOUND,
AND THE THIRD OR FOURTH SOUND IS
THE FAX SOUND, WHICH IS A SORT OF
STATIC-LIKE WHISTLING SOUND.
WHEN YOU HEAR THE FAX SOUND, THAT
IS WHEN YOU PRESS THE SEND FAXCIMILE
BUTTON.
I HAD A SIMILAR PROBLEM WITH A FAX
MACHINE ABOUT FOUR YEARS AGO.
IF THE FOREMENTIONED INFORMATION
DOES NOT HELP, YOU MAY WANT TO
RECONFIGURE YOUR FAX SEND AND
RECEIVE SETTINGS. REFER TO YOUR
OWNER'S MANUAL FOR TECHNICAL
DATA.
GOOD LUCK.
FROM
TEXASDUDE2008
Mar 12, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Print Size Changes
This maybe down to the other persons fax machine if your copy is coming out perfect try sending it to a different fax number to see what happens.
If the same thing happens press the menu key and you are looking for a heading call setup or machine settings within one of those will be TTI settings and make sure that reduction send is not on.
Hope this helps sorry a little vague but have manual at work
Thanks J
Nov 22, 2007 | Brother IntelliFAX 560 Plain Paper Fax
Brother MFC-3220C Plain Paper Inkjet Fax Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
