Question about Photography
Which buttons to push
Do I need to push the button and the leaver to take a picture?
    Genius:
  • 1,044 Answers
1 You have to push the button to take the picture 2 Some of the cameras are auto loading. In that case once you take the picture it will move the film automatically. 3 If it is not auto loading then you have to move the lever to load film for the next shot
Posted on Nov 19, 2009
Why my truck will not go into park
It could the button on the shifter not going in , check if it goes into park at the trans. by disconnecting the linkage and push the leaver by hand .
Aug 15, 2014 | 1999 Ford Explorer
How do you open the gas cap cover
Pull the leaver or push button inside the car,it could have a broken cable.
Feb 22, 2014 | 2013 Fiat 500 - Gucci, hatchback, with...
Elna 600 manual
I'm not sure about your machine but I've used an Elna that had a leaver for stitch length and when you pushed the leaver up all the way it would activate reverse stitching.
Apr 22, 2013 | Elna Sewing Machines
Automatic button hole not working in ambition 1.5
it sounds like the machine needs some adjustment in the buttonhole
gears or the cam could be damaged.
Jan 04, 2013 | Sewing Machines
V/74088/620
I am having the same problem. Initially it did sew forward, but now only sews in reverse. The large grey lever on the right front of the machine should make it sew in reverse only as long as it is held down, but mine sews in reverse only. Hmmmm....think there are many people with this problem.
Jan 30, 2012 | Janome 2049LX Mechanical Sewing Machine
I need a video tutorial on how to replace the CD-ROM drive in the Fujitsu Siemens Amilo Pro V2010.
All you need to do is leaver off the power button strip with a thin screwdriver. The power button strip has a slight gap at each side this is where you insert the thin screwdriver or thin leaver.
The power button strip has two plastic locking down lugs at each side they hold it in place.
Do it from the power on button side first with the screen flat backwards or you will pop off some keys.
Getting off the power button strip is the hardest part without poping off keys or scratching the case.
Unscrew the single silver screw to release the key board this screw is located slightly to the right of center although there are four locking down tabs on the keyboard it is only held down in the second one from the right. (It’s the longest screw in the laptop)
Push the keyboard slightly forward then tilt the keyboard towards you and lay flat (you should have enough strap to do that)
If you want to remove the keyboard completely you have to lift up the left and right lug each side of the strap)
Just at the right top edge of the strap connector you will see a silver headed screw, remove it.
The CD/DVD writer is now free however at the end nearest to you it is pushed into its electrical socket which is part of the motherboard.
If you press on the silver metal bit that you removed the screw from (looks a bit like a top chopped off triangle) the writer will slid out of its electrical socket, the device will come out from the right side of the laptop.
Remember if you are replacing the writer you will have to get one with the correct electrical socket.
Replacement is the reverse of removal. Slid in the DVD writer make sure it slots into the electrical socket. Put the locking screw back in. Locate the keyboard in its forward slots and slide in the strap, lock it into its connector, by pushing down the lugs either side. Lock down the keyboard with its screw and push back into place. Push the power button plastic strip into place.
Do the operation with the battery out and the power adaptor disconnected.
Hope this is clear enough and helps.
Feb 16, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
No I am not locked out The button on my key
You can take the trim panels off, around the trunk lever and manually pull/push the cord.
Jan 05, 2010 | 2003 BMW 325
The over drive button stuck in and will not release nedd some help to fix
Common problem with tilt steering. In park or neutral try pulling the shift leaver back and forth while pushing the button repeatedly.
Good luck.
Sep 30, 2009 | Ford F-150 Cars & Trucks
Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
Sep 06, 2008 | Fellowes Powershred 480 Shredder
Photography Logo
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
