Question about Vulcan 36L Gas Kitchen Range
Have problem with Vulcan oven going out too. Where is valve magnet?
We have struggled with the same oven problem. We have replaced the safety valve & thermocouple numerous times. Is the valve magnet you referred to in the other solution email in the safety value assembly or is it in the main red on/off valve for oven(with temp settings)? We have found that if we pull the heavy bottom panel out of the bottom of the stove it runs non-stop..why do you think that is?. The baked finished product is not so good with this quick fix.
Thanks
Denise
  • Anonymous Dec 02, 2008
    Our oven shuts off when the temp is reached
  • a2zresearch Dec 02, 2008
    Vulcan EG 36
Looking for teh answer to the same problem
Posted on May 17, 2008
Gas valve on Vulcan oven SG4D-1 makes a chattering noise?
if it is a buzzing noise it is usually not big deal. If it is truly a chatter, I suggest replacing as the electric coil is going bad.
Jun 19, 2017 | Vulcan Ovens
PILOT LIGHT WONT STAY LIT i CHANGED THERMOPILE
pilot flame to small
over temp safety thermostat trip
dirty connection points
thermocouple fail not the same as thermopile fail
thermopile drives the gas valve.700MV
thermocouple drives the pilot light safety system.30MV
gas valve magnet fail
check the above for any faults
Jan 19, 2016 | Kitchen Appliances - Others
Hot water heater pilot will not light
You have red wires connected to bottom of gas control valve?
Is this a power vent model?
What model, what brand water heater?
Is new thermocouple is finger-tight plus 1/4 turn and not shorted against gas control valve?
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Copy following link for safety magnet:
Magnet will click closed when pilot is turned off. Put butane lighter on end of thermocouple and listen for clicking sound.
http://waterheatertimer.org/pdf/Safety-magnet-Gas-control-valve.pdf
Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Bad gas control valve:
Low gas pressure, air in gas line, inadequate air supply, clean the air intake, tripped FVIR system, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 28, 2012 | Water Heaters
Wall heater will not work, even with thermostat in on pisition
Your thermocouple may be shot.
Have ya try to replace that one?
A simple thermostat now let me show ya a video of a man that has replaced his thermostat. Even though that gas valve is a bit different the thermocouple does the same function and that is hold down the safety magnet. Now watch:
Replace that thermocouple on your heater.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 18, 2011 | Williams (5009622) Ceramic Gas Wall...
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Jan 10, 2011 | Vulcan G36L Gas Range
The pilot lights ok,the burners light,but after sometimes 5 to 10 minutes later both will go out
The gas for both passes thru the FMDA Safety Valve - in you case it's defective and must be replaced. You can find it here
http://midwestapplianceparts.com/stove-oven-range-58/vulcan-hart-parts-773/oven-safety-valve-1050/vulcan-hart-fmda-safety-valve-6253.html
Oct 02, 2010 | Vulcan EF3 Deep Fryer
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Pilot will not light
Unable to light pilot Gas supply turned off Turn on gas supply Gas **** knob dial not positioned correctly Check lighting instructions. Set control knob Defective thermocouple Check and replace thermocouple Defective safety magnet assembly Check and replace gas valve Pilot burner orifice clogged Clean or replace Pilot tube pinched or clogged Clean, repair or replace Poor thermocouple connection Check and tighten Air in gas line Purge air from gas line Thermostat's single use ECO is tripped Check ECO and replace gas valve Gas valve defective Check gas valve
Jun 06, 2010 | American Standard AMERICAN STD 100G NGAS...
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
Describe what could be the problem if my oven will light but not stay alight once I release the gas button
That could be one of 3 things: The thermocouple could be bad, the hole that the thermocouple screws into could have corrosion and causing a loss of electrical current to the safety magnet. Or the safety magnet itself is bad. The thermocouple when heated generates electricity. The magnet inside the valve is powered by the thermocouple. If the pilot light goes out the magne looses energy and the spring attached to it shuts off the flow of gas. Pretty clever ain't it?
Jan 20, 2010 | Ovens
Vulcan 36L Gas Kitchen Range Logo
804 people viewed this question
Top Vulcan Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
