Question about LG TracFone 600 Cell Phone - TF600GP4
No screen, need a walk through on transferring the info inside.
Wiring in a transfer tank pump in 2011 dodge 3500
Will you have 2 separate tanks, You will need to run the fuel line safely up against the frame to where you want to mount it and add the new pump. You will need a valve that shuts off one tank then the other as you need it. I'm sure you can find one with the info in the box. Use your original pump to feed the motor.That is if it's a puller pump. You tube might make it simpler? Get ahold of me and
i'll walk you thru it!
Jan 28, 2013 | 2011 Dodge Ram Pickup 3500
Dropped my phone about 3 feet. it landed flat on its back. from then on the screen is white no display at all. the info is still inside how can i fix this?
The only way to retrieve your information is to transfer it to a computer, or have your carrier transfer it to your new phone.
Mar 03, 2011 | Motorola Mobility MOTO W755 Cellular Phone
Cannot transfer tape contents to PC
To transfer video from your camera you will need a firewire cable and a firewire port on your PC. If you don't have such a port you can buy a PCI firewire port.
After you connected your camera with firewire cable you can then use windows movie maker to transfer your video.
See this for more info and photos
Feb 28, 2010 | Panasonic NV-GS400 Camcorder
I need info on how to switch the case out
There is no written instructions. I looked online but there isn't any.
Follow this instructions
1)with the game-boy screen facing you, there are 5 round things there.
3 up and 2 down the screen.
2) put your screw driver inside there and remove it. Do it to all of them.
3) there are screw(nuts) inside those round things. so remove the screws(5) with the screw driver.
4)Don't open the LCD yet. Turn to the back of your gameboy, there you see 6 srews(nuts). 2 up one middle(for the battery) and 3 down. Remove the screws.
5) after you remove all 6 screws, the middle screw is for the battery. open the cover now the screw is gone and remove the battery.
(please remove any screw you see where the was before)
6) Open your game-boy with knife or with anything possible for you then the screen.
remove any screw on the board inside of the game-boy.
slowly and carefully disconnect a cable that is connected to the motherboard( LCD cable)
7) remove the speaker and then transfer it to the new skin, remove all the buttons and transfer then, now put the motherboard to the new skin, remove the Screen(LCD) then transfer it to the new skin. put the LCD cable you disconnect from the motherboard back. put the motherboard screw back. put the LCD screw back.
8) Turn to the back of the game-boy and put the battery back and all crews back. Now you are set enjoy!!!. feel free to ask me any question.
Jan 24, 2010 | Nintendo Game Boy Advance SP Console
How i can use ipod with my car audio system
Inside the armrest you will find the ipod audio input jack. Your sales rep should walk you through this. Once plugged in the ipod will display in the AUDIO , AUX position in your info screen of the NAV system.
DEPENDING ON THE LEVEL OF TRIM, THE CAR ALSO HAS A SOUND LIBRARY CAPABLE OF RECORDING 2200 SONGS TO THE AUDIO HARD DRIVE, FROM CD OR OTHER SOURCES.
Enjoy the ride. You have made an awesome choice of car. Post back with more questions
Oct 22, 2009 | 2007 Lexus LS 460 L Sedan
MY SCREEN IS COMPLETELY WHITE....I NEED TO SAVE MY NUMBERS TO THE SIM CARD BUT I CANT SEE CAN SOMEONE WALK ME THROUGH IT TO TELL ME WHAT BUTTONS TO PUSH. I HAVE A SAMSUNG A 737 SLIDER I have a Nokia 6131...
Hey..
Im guessing that your settings is set to default for this to work..
-turn fone on.
-wait for a while to load up.
-press select button(middle).
There are two ways of doing this depending if your menu is set to grid or listing.Remembering is the key for it to work.
Grids:
-arrow down once
-select
-arrow up up once
-select
-select
-turn fone off after 5minutes and transfer to working fone.
List:
-arrow down 7 times
-select
-arrow up once
-select
-select
Hope this helps..
May 05, 2009 | Nokia 6131 Cellular Phone
Black screen: Motorola v557
need more info. of black screen !!! If it is no desply butr has a power probebly the lcd connector has a busted small parts but if it is has a desply but no light the most problem is the back light most of the time replacing lcd is the best way to fix the problem ......
May 13, 2008 | Motorola Mobility V557 Cellular Phone
LCD screen r/r
For the details on how to disassemble please try laptopscreen website. However if you can manage to unscrew and unlock the opposing frame. Please see the screws covered with rubber fittings or sticker and opening the lock notches' by pushing with thing flat screw drivers. Hope this helps.
Best regards,
Rosener Guyano
Nov 15, 2007 | Computers & Internet
My Phone Has A Big Thumb Print On The Front Screen And The Inside Is Whit With Shades Of Blue Through It...What Do I Do?
Take off the front cover/faceplate of the phone and you should see the screen. You can clean that one and it should help. It it is the inside one, you have to take off the screws in the sides to get to the internal screen.
Jan 25, 2007 | Motorola Mobility A630
LG TracFone  600 Cell Phone - TF600GP4 Logo
59 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
