Question about Electrolux Refrigerators
We bought a 2nd hand frigidaire side by side and the water/ice despenser light bulb is missing. Where can we get a new bulb and what size/type do we need to get?
  • 612 Answers
You can use a regular night light bulb that you can buy from WalMart. It's the same bulb that is used in the large Christmass lights. Without the model number this is a guess but around 85% or the units on the market use this bulb. Good luck and have a great day.
Posted on Nov 19, 2009
Side by side ice and water dispenser
Did you replace the bulb with one of the same voltage rating?
Seems strange that a new bulb should blow straight away, maybe it was faulty.
This sounds like a blown fuse.
Oct 13, 2007 | Frigidaire FSC23F7D Side by Side...
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
Why is my refrigerator leaking water inside
It sounds like the flap in the door for the ice despenser is missing or is sticking open. The room temperature will lower the temp in the ice bucket enough to partially melt that ice, OR cause a LOT of condensation that may freeze or re-freeze.
Aug 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Smart light not sensing darkness
there is a small pc board right there in the front panel it sontrols everthing from the light to the water and ice despensing . there are a lot of problems with this board and there not cheep from 65.00 to over 100.00 . i would wait untill another part of it fails ,and it will your water will go out ,or your ice . then you will be forced to replace it most only last 5 years ( new refrigerators are only lasting 7 to 10 years ) good luck
Mar 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Where is the drain?
Hi, Well could you tell me if your f/freezer is frost free? Or is it a wet wall type fridge? I.E. water running down the back of the fridge? This would help me in telling you what is wrong. As for the water despenser you will probably find that there is a small bit of scale in the water valve which lets the water in or that there is a scale build up in the water despenser in the door. This does happen even tho you have a water softner. You will need to check both as to ascertain which it is.
Dec 30, 2008 | Frigidaire FRS26R4A Side by Side...
The ice cubes come with white powder
Hey there....
The white powder in your ice cubes is the water line to the dispencer,The water in the pipe forms a white layer after some time,almost like the kettle around the aliment,you just have to clean the pipe out,i normaly use some hot water with a bit of vinigar,just make sure you flush the system after wards and there you go....
Hope you get it right...
Wouter.
Sep 10, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
