Question about Dell Dimension 2400 PC Desktop
My computer is showing a floting box which say self test feature check, wit red,green blue and white box.What do this mean
  • 46 Answers
Its showing u monitor self test feature screen issue either with the monitor cable or monitor or the graphic card
Posted on Nov 19, 2009
Replace et724-A with new digital timer 15313
You are install GE 15313 timer
Open following link to identify timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
15313 timer does not require Neutral wire.
The timer you are replacing has neutral wire (White wire)
So replace timer wires 1:1 except do not connect timer to white neutrals.
Keep in mind the 15313 is for incandescent lights only and is not for CFL or LED lights.
If you want timer for CFL, then install one of the other timers shown on page.
Apr 29, 2012 | Intermatic Inc. EJ500C Digital Wall Switch...
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
The monitor will not show a picture the led is flashing green
* If the issue is visible in the monitor STFC (Self-Test Feature Check), the monitor is defective. * If not, the issue is with either the video card driver or the video card.
* Turn off both your PC and monitor * Disconnect the monitor from the PC (either the white DVI or the blue VGA. They should never be connected at the same time to one PC) * Turn the monitor on * The floating Dell red/green/blue/white dialog box should appear on a black background * Check for the issue
Mar 02, 2011 | Dell E173FP 17" LCD Monitor
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
E153PFc Dell monitor: cannot change resolution
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating red/green/blue/white dialog box should appear on screen against a black background. What appears?
Jul 17, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Computer powers up, but monitor shows a self test
Your video output is bad. Either the video card, or the onboard video built into the computer. You need to swap out the card or add a card to bypass the built in video port on your computer.
Thanks and please take a moment to rate as fixya.
Feb 11, 2009 | Gateway 550GR PC Desktop
Dell172fpb 17" monitor
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Monitor trouble shooting
what would i do for my monitor that went blank
Apr 07, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell Dimension 2400 PC Desktop Logo
825 people viewed this question
Alun Cox
