Question about Kitchen Ranges
My pacific hood range has only a black and white wire. What do I connect the ground to on my hood range? Is the hood range missing a wire?
  • 11,896 Answers
Ground wire goes to any metal surface for a ground. Hood, junction box, ect.
Posted on Nov 19, 2009
My hood is fitted with 2 x 20W Halogen G4 capsule bulbs. Both lights are flickering. Changing the bulbs and cleaning connectors has not resolved the problem.
You have a problem with the wiring. Check the ground where the power is connected to the range hood. Make sure the ground is tight and secure. Also check both the white neutral and black power connections. Remove the wire nuts and look to see you have a solid connection. Replace the wire nuts tightening them securely. Be sure and turn the power off at the breaker panel before working on the unit.
Feb 08, 2011 | Kitchen Ranges
What color wire do you connect to the plug in for the Kenmore range model C970-44073800? We purchased a four prong plug in and it states on it to refer to the appliance to wire it correctly. The only wire...
White is your neutral. Red and Black are L1 and L2. The 4th wire is the cabinet round. The round post is the ground, the one directly above it is neutral(White) the other 2 don't matter which one is Black or Red. You can verify the connections with a meter, Red to Black - 240VAC, White to Red or Black -120VAC White to Ground -0VAC
Eric
Mar 10, 2010 | Kitchen Ranges
Pacific range hood hass two and one green cord, wall has black, white and ground. Which black cord do I attach to the white?
It doesn't matter as long as the green is to ground. If you were powering multiple units in series it would be different, but in your case it doesnt matter.
Aug 24, 2009 | Kitchen Ranges
Jenn-Air 30 in. Under Cabinet Hood had no instructions on how to
This is a straight forward wiring project involving 110 volts of electricity and a 15 amp circuit.
If there is already power available at this location use it. If not, run a wire to the cabinet above the hood location with enough extra to drop down into the hood area and hook it up.
Once you have the power wire in place it is just a matter of hooking the wires up black-black, white-white, ground-ground screw.
enjoy your new hood.
May 26, 2009 | Jenn-Air 30 in. Pro-Style Range Hood
Electrical hookup
If you have the hot and common wires connected (black to black and white to white) it should work. If not, try connecting a length of wire to the ground wire and connect to ground, such as a copper cold water pipe, radiator, heater vent, or the ground terminal in a nearby outlet. If it works then, you need to splice an extension to the ground wire to connect in the box where the hot and common are. Keep in mind all splices must be inside an approved box. If it still doesn't work, yours is not the first nor the last defective hood to be sold.
Feb 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Zephyr ep30 range hood
That green and yellow is your ground wire....wire nut that to your bare copper wire feeding the hood.
Sep 03, 2008 | Zephyr Pyramid ZPY-E30S Kitchen Hood
Wiring hookup
The 2 black wires on the hood go to the black from the wall. The 2 black on the hood is in case you want separate switches as 1 is for fan and 1 is for light. The green goes to the bare copper wire. Its the ground. And are you sure the wire is yellow? It should be white and connect to the other white. This is the neutral.
Mar 01, 2008 | Miele Designer DA230-2 Kitchen Hood
Whirl pool dryer
L1 Hot= Left terminal (Red Wire) ...... L2 Hot= Right side terminal (Black Wire) .......... Netural = Center terminal (White Wire) .................. Ground is Green connect to the cabniet of the unit and remove the connection strap from the center terminal on thje dryer wiring block..
Feb 22, 2008 | Kitchen Ranges
Miele DA230-2
The latest DA230-3 hood is a 120V 15amp model and has a black/red wire to live, a white wire to neutral and a green to ground.
You may have a 220V model. I suggest to have a licensed electrician hard wire according to the voltage, load, and circuit rating listed on this data plate.
Dec 26, 2007 | Miele Designer DA230-2 Kitchen Hood
Kitchen Ranges Logo
272 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
