Slow spinning MTG6234DT1 spins slow or not at all
  • Anonymous Dec 13, 2008
    washer starts out fast then get slower
    1. washer starts fast then gets slower
  • 164 Answers
Time to replace your belts or something is stuck between the inner and outer tubs
Posted on Jan 11, 2008
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Washer spins slow or doesn't spin at all
Hello, If your machine is spinning slow, this can be an indication that your gearcase (transmission) may be going bad. One way to tell is to look under your machine. If you see any oil puddles on the floor, your gearcase needs replaced. A new gearcase runs about $200 and that doesn't include the labor charges (add about another $150). Good luck.
Thanks
May 19, 2010 | Washing Machines
Washer spins but too slow
Clean out the drain pump. Sounds like water is pumping out too slow. This added weight is slowing down the spin.
If water is pumping out OK and you still have the same problem, replace the drive belt.
Apr 01, 2009 | GE Washing Machines
Kenmore washer spins slow or will not spin
taking that it will wash,,you have a bad transmission,,onthejob
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Jan 14, 2008 | Washing Machines
Slow spin
Top loaders have a belt and a clutch. The motor has two sets of windings, slow for wash and fast for spin. You need a service engineer to correctly diagnose and fix.
There are parts here, but you need to correctly diagnose the fault.
Kenmore Washer Parts Repair Parts Sears PartsDirect
Feb 20, 2018 | Kenmore 42182 Top Load Washer
Washing Machines Logo
274 people viewed this question
Top Washing Machines Experts
