Question about HTC S621 Smartphone (Unlocked) - Black/Silver
Can i turn on my htc dash other than the power button on the side?
How do u reboot the htc one
If there's a problem with your screen or you're otherwise unable to do a factory reset via the settings menu, then you can use the hardware buttons to do a reset too. Simply turn your HTC One off, then press and hold the Volume Down and Power buttons. Continue to hold them until you enter the H Boot screen.Aug 23, 2014
How to hard reset the HTC One - AndroidPIT
https://www.androidpit.com/hard-reset-htc-one Feedback About this result
HTC One (Verizon Wireless) - Restarting HTC One (Soft reset ...
www.htc.com/us/support/htc-one-verizon-wireless/howto/394150.html
  1. Cached
  2. Similar
Restarting HTC One (Soft reset) If HTC One is running slower than normal, is unresponsive, or has an app that is not performing properly, try rebooting and see if that helps solve the problem. If the display is off, press the POWER button to turn it back on. Press and hold the POWER button, and then tap Restart.
HTC One - Resetting HTC One (Hard reset) - SETTINGS & SERVICES ...
www.htc.com/us/support/htc-one/howto/365649.html
  1. Cached
  2. Similar
Performing a factory reset from settings. Go to Settings, and then tap Backup & reset. Tap Reset phone. Tap OK.
How do reboot the htc one Google Search
Nov 08, 2016 | HTC Cell Phones
How do i unlock my htc after many pattrn attepts
What type of HTC phone EVO Incredible? I suggest a hard rest as you cannot get into the phones menus. A hard rest will put you back to factory status you will lose all your pictures,music,data,etc.
To perform a hard reset using the device keys:
  1. Turn off your phone
  2. Press and hold the volume down button (located on the right side panel), and then press the Power button
  3. When the display turns on, release the volume down button
  4. Use the volume buttons to select CLEAR STORAGE, and then press the Power button
  5. All data will be deleted from your phone Your phone might be slightly different but try this
Feb 27, 2015 | HTC Desire HD A9191 Smartphone Unlocked
I went cleaning my htc p5500 screen with a dap clothes and rub it up and down now the touchscreen isnt working,jus would like to know if i reboot it will the touchscreen work?
FOLLOW this steps and fix it. God bless you
  1. Hard Reset
    • 1
      Pull out the stylus from the back of the HTC Touch Diamond or the side of the HTC Touch Pro.
    • 2
      Using one hand, press and hold the volume down button on the left side of the device, the power button on the top of the device and the circular button on the face of the device. It is generally easiest to hold the volume down button with your thumb, have your palm over the LCD, press the power button with your index finger and the circular button with your pinky.
    • Sponsored Links
    • 3
      Continue to hold the buttons down while you turn the device over to access the back side. Use the stylus to press the "Reset" button, located near the end of the stylus cavity on the Diamond, and by the port on the bottom of the device on the Touch Pro. Release the "Reset" button, but do not stop holding the volume down, power and circular buttons.
    • 4
      Turn the HTC Diamond over and watch the LCD. When a message appears saying that this operation will delete your data, release the three buttons. Press the volume up button to complete the hard reset.
    Clear Storage
    • 5
      Slide your finger to the right along the bottom of the LCD until the "Settings" option appears. Tap "All Settings" on the device.
    • 6
      Tap the "System" tab on the screen and then tap "Clear Storage"
    • 7
      Select the drop-down box and choose "Clear Storage Only." Type "1234" into the text box confirming that you do want to delete your information and then press "Yes."
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
Well. I dropped my phone, which is a HTC Dash S60, really bad due to my brother and the power button came out. Is there a way to push something down through the power button hole to turn it on?
Yeah sure. I mean, the rubber/plastic buttons are just padding for the motherboard underneath the keyboard/menu buttons. You should still be able to turn it on/off by pressing down in the spot where the power button was. This is some poor cell phone construction...
Oct 09, 2010 | Cell Phones
Won't turn on
Obviously first thing is battery, maybe it is defective. Or it could be contacts in the battery compartment. Or the power button. You could try the soft reset (right-hand side of the phone under the back cover, a red (or green) button.
Aug 01, 2010 | HTC Touch Pro2 Smartphone
Mobile loss some internet machine code drivers
ok, follow this steps, this will reset your phone to what it used to be before you messed with it. SAVE ALL YOUR INFO, VIDS, N PICS:
1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
Second Option> Hard Reboot:
How to Hard Reset a T-Mobile Dash and HTCS620 without the operating system:
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send" button which is considered as the green phone button.
hope it works
May 18, 2010 | HTC S620 Smartphone
My power button doesn't work, can i turn on my dash with the keyboard?
No, you can only turn on the phone with the power button. If you feel comfortable opening the phone, then if you jump the front and back leg of the power switch, then it should turn the unit on if the switch is bad.
Dec 09, 2009 | HTC S621 Smartphone (Unlocked) -...
How can do reset my htc touch p3450?
soft reset no data wiped off press the power button upside of pda for 5 seconds it will turn off then press it again to switch on
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Feb 19, 2009 | HTC Touch P3450 Smartphone
My HTC smartphone doesn't power on despite charging
try pressing the reset button near the charging port on the pda if it doesnt work try to hard reset it as follows other wise check xda forums for software dead HTC
Feb 10, 2009 | HTC Touch P3450 Smartphone
Please help, I can't turn on my HTC. What happened?
If you have a charged battery insert it and power the phone. If it hangs or whatever then (with the phone powered on, regardless of what's been displayed) keep on the keypad the two dashes ( - ) pressed and do a reset with the stylus. Do not leave the two buttons untill a black screen appears and ask you to press send (the green call button). Press it and you are done. If your phone doesn't have a hardware damage it should start. It will start from scratch again so you might be a bit patience.
Oct 08, 2007 | HTC P3300 Smartphone
HTC S621 Smartphone (Unlocked) - Black/Silver Logo
63 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
