Question about Philips FWP900 System
Speaker Problem The sound on my left speaker breaks up, somedays the speaker works and sometimes it dies. I know its not the cable which Im scared that it may come down to the speaker itself, I don't put it very loud.
  • ChemicalBurn
    ChemicalBurn Jan 11, 2008
    Well I switched the channels like you said, so far both speakers sound great like when I first got it. Ill keep the music going for another 12 hours to see if it holds up cause before this happened the speaker dies in about a few seconds. With the switch its been running smooth for already a half hour.
    Problem Solver:
  • 12 Answers
Try swapping the speakers to the opposite channels (left and right) and see if the problem is on the same side. If it is, then you may have a bad channel in your amplifier/receiver.
Posted on Jan 11, 2008
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
Handset earphone doesn't work.
Sometimes the earpiece plugs up with dirt/dust, which could potentially block enough sound that you can't hear anything through it (my HTC OneX+ is doing this, and I've been using the speaker-phone on it for months now. Someday I'll take it apart and clean it... someday...) You could try removing the casing and other components to get at the speaker and clean it up.
Your phone's earpiece could also be non-functional. I'm not sure about this particular model, but as with many HTC phones, the little earpiece speaker can usually be replaced. The hard part is actually getting to it...
Dec 11, 2014 | HTC Wildfire A3333 Cell Phone
Left speaker not working
I don't believe it to be a cable or plug problem, so it sounds like it's a speaker problem. I look up the review of these and it could have some kind of circuit built into each side. If it does it could be that. As they are not cheap headphones by the look of it, perhaps worth repairing. But if the speaker has gone, it might be as much as a new pair.
Jan 03, 2014 | Sennheiser HD 558 Headphones
Sound goes out & speakers "disappear" from computer prefs panel
I would open it up (assuming it's a desktop pc not a laptop), and make sure the sound card (if it's an expansion card and not built-in to the motherboard), is properly seated (all the way in) in the expansion slot.
Feb 18, 2010 | Harman Kardon Harmon Kardon SoundStick II...
There's only sound in the left speaker.
when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Jun 24, 2009 | Stanton STR8-30 Turntable
My speakers only work one at a time...
Check you have plugged them into the correct socket on the back of the PC ..
Chances are you have 3 sockets - first = 'front' (or pair), middle = 'back' (for 4+ speaker sets) and last = 'center & sub-woofer' ..
Sounds like you have plugged into the 'center & sub-woofer' socket :-)
Mar 13, 2009 | Dell A215 Computer Speakers
I sometimes lose sound from my left speaker and it crackles.
this is a speaker input pin problem, like pin is dameg or input pin is not atech proparly in computer problem is still present remove the cable and install new one cable in speaker
Mar 11, 2009 | Audio Players & Recorders
Philips FWP900 System Logo
101 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
