Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How do u reset tv cuz power will not turn on. ITS A MITSUBISHI HD MEDALLION SERIES TELEVISION
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Medallion HD 1080 model ws-48413
when the led is flashing does it flash a two digit error code? Let me know I should be able to help you with it.
Posted on May 08, 2008
SOURCE: TV Won't Power on Green Flashing Timer Light
Here's a guy who fixed it himself, with no prior soldering experience, and completely documented the process.
check it out here:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
The only thing I would add, based on all the online Q&A sites, which all agree that replacing the seven (7) Capacitors on the DM board is the recomended fix, is to upgrade the Capacitors to:
1000 micro Farads @ 25Volt 105 deg.Celcius
Posted on Jul 26, 2008
SD Tech
  • 14553 Answers
SOURCE: Misubishi Medallion 1080
If this is a ws-65411: it sounds like one of the two STK-392-110 convergence IC's is bad; you need to have both replaced at the same time; I do this type of repair(done hundreds of them) and most can be done right in your home.
The two ic's can be purchased on Ebay for about 12 dollars plus shipping.
This is the slow time of year for TV repair shops--find someone in your area who knows how to do this kind of repair---here shops charge 3-4 hundred but I charge 200-250 total depending on brand of set.
Shop around and if they insist on "taking set to shop" keep looking---any good tech can do this repair in your home---MAKE SURE HE CHANGES BOTH of the IC's!
I do this here for free so if this has been helpful give me a vote here.
Posted on Aug 24, 2009
Testimonial: "very helpful"
  • 418 Answers
SOURCE: Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Posted on Apr 17, 2010
  • 31 Answers
SOURCE: have a Mitsubishi Medallion HD 1080 Model WS-48413
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Posted on Jul 06, 2010
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
I have a mitsubishi medallion hd 1080 series t.v.
yes, for under thirty dollars you can replace the chips in the set and have it working again.
Apr 17, 2012 | Mitsubishi WS-55819 55" Rear Projection...
I have a 63 inch projection tv, 8 years old, that stopped turning on last week. Not sure what's wrong with it. You can hear the power turn on inside the television though the screen does not turn on. No...
LOOKING AT THE AGE OF THE TV IT MIGHT HAVE DRY JOINTS ON PCB,S SO IF U KNOW ABOUT ELECTRONICS AND GOT SOLDERING IRON RESOLDER SUSPECTED SOLDER JOINTS AND THEN TRY.
Aug 12, 2010 | Mitsubishi Televison & Video
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi 55" - Stretches screen
on the frount you should have ch up , ch down,
same for volume , and menu. press menu
and scroll down to VIDEO or SET UP
try one of thoes sub menu will have FORMAT
4:3 - 16:9 seting its a little differant on
on same make diferant models , you may
have to do a little hunting to find the setting
Jul 02, 2009 | Mitsubishi WS-55807 TV
Can't loate bool;et for Mitsubishi HD 1080 Series Medallion
it is usually in the Audio settings,sometimes by the CC settings, if you go to the TV and enter th menu from the set, go thru one at a time until you find the spot to turn it off, it is under options or Menu on the remote also, there maybe an SAP Option on the remote itself, but you may have to press another key first like a "Function: Key.
I hope this helps some, if so please give me a good (fixya) rating. Thanks and have a Blessed Day
Apr 08, 2009 | Televison & Video
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
