Question about iRobot Roomba 560 Robotic Vacuum
This is a roomba 560. First started acting crazy, ''even ''singing'' on the base. No no power at all, no clean botton light at all, the base turns green when you put it in there like charging ... The baterry measures little over 14V. I tried to reset it but no change...
    Scholar:
  • 58 Answers
Something is blocking the battery current and preventing the Roomba from running.
Low voltage contacts can be blocked by thin films formed by condensible organic outgassing in the home environmental (That's the yellowy haze that slowly builds up on the wall paint.)
Try cleaning the battery contacts with a little rubbing alcohol or contact cleaner on a foam swab, or a bit of paper towel. Take a litle time, it doesn't always dissolve instantly. (Don't use a pink pencil eraser, it would scrub off the plating that prevents corrosion) Clean both contacts on the battery pack and both of the contacts in the Roomba. Make sure the battery is oriented correctly when you put it back in.
If that doesn't help, the battery itself can be defective such that it has a very high internal resistance and can only charge and discharge very slowly. It can be fully charged, and unable to deliver that charge at a pace that allows the Roomba to operate. Sometimes its possible to rehabilitate such a battery by conditioning it over several charge and discharge cycles, and sometimes its ineffective. Since thr Roomba won't run you'd have to use a something like a 20 to 50 ohm power resistor to drain the pack to 10v before charging it.
Of course as your description suggests, its also possible the processor has a fault and you need to buy a new one.
Posted on Dec 13, 2009
Roomba 595 no lights - not charging
Just a idea but have you tried replacing the battery? Here is a link to a forum on this topic.
http://www.robotreviews.com/chat/viewtopic.php?t=2901
Dec 29, 2015 | iRobot Roomba 560 Robotic Vacuum
My Roomba 500 series, when I press it to start, it wants to and then makes a singing song and does not go forward
Be sure that you clean the brushes and wheels under the unit. If they have material wrapped around them the unit will not proceed.
Feb 23, 2015 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
How do I change schedule on Roomba
go to roomba.com when at there site go to customer care support then to pooduct resources then select a robot roomba,scooba,ect find your sereies 700,600 ect go to documents&manuals then to scheduling roomba then to viewing and deleting schedules follow the steps
Dec 18, 2012 | Roomba iRobot 560/561 Vacuum Cleaner...
I have no instructions for my roomba 560 so dont know how to start it
Turning Roomba on and off • To turn Roomba ON, press CLEAN once. You will hear a beep and the CLEAN button will light. • To start a cleaning cycle, press CLEANagain. Roomba will start a cleaning cycle. • To pause Roomba, press CLEAN while Roombais cleaning. • To turn Roomba OFF, press and hold theCLEAN button until Roomba's lightsturn OFF.
Sep 21, 2011 | iRobot Roomba 560 Robotic Vacuum
560 backs out of charging base then only turns in right circles
Yes, this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
Here is a guide to fix it
http://www.schneordesign.com/Avi/irobot/roomba_mod2.htm
Have fun
Avi
Dec 05, 2009 | iRobot Roomba 560 Robotic Vacuum
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba 560, the small red light above the schedule button will not reset and the roomba will not run. The problem started when I the roomba sat dead for 12 hours. I tried the spot dock reset trick with no...
You should start by removing the "belly plate" of the Roomba and simply removing the battery to cycle power to the unit. If that does not solve the problem, it sounds like you need a replacement circuit board for the 560. That's alot trickier since iRobot doesn't like to sell those...they want you to send to them for service.
Your options would be to send to a reputable Roomba repair center like www.protechrobotics.com or you can buy a replacement PCA from places like www.RoboticVacParts.com and replace yourself.
May 07, 2009 | iRobot Roomba 560 Robotic Vacuum
Wont charge
did you try plugging in 560 driectly to charger then run it?
Dec 26, 2008 | iRobot Roomba 560 Robotic Vacuum
Roomba Scheduler will not dock
Clean the contact on the robot and it will dock.
Nov 16, 2008 | Roomba Robotic Floor Bagless Vacuum
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
291 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
