Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
No water out of the filter spout
I have turned on, did the procedure to get the airlock gone witht he froth nozzle (in manual), but I still have no water out of the coffe spout
  • 2 more comments
  • Anonymous Mar 02, 2008
    Gaggia Coffee Deluxe will not emit water for coffee under any pressure. On beginning the brew cycle, for a second it the pump sounds strong. Then the motor produces only a weak sound, and the water drips slowly through the grinds. The problem began after I cleaned and descaled the machine. Hot water and steam is emitted normally, with good pressure.
  • RalphK May 15, 2008
  • Anonymous Jul 24, 2008
    great pressure for steam water on the coffee side
    New bolier- no help
    completing trouble shooting.. no help
    Could the wires be crossed....anyone have a wire diagram
    97 delux??
    Al Brandano
  • Anonymous Jan 30, 2009
    I have just bought a Gaggia baby class and there is no water coming through the machine at all. I also have a Gaggia Cubika so I am familiar with this type of machine.
  • 515 Answers
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Posted on Jul 17, 2008
When brewing coffee about half the water comes out of the frothing nozzle instead of the coffee spout. The nozzle also leaks after the brewing cycle.
I would say that something has a hole in it, but if it doesn't it might have bad quality, and if it isn't that because the place where you bought it from sells good machines, then it still might have something that went wrong or something was misplaced. I'm not sure either, but that's what i think is the most likely reason. You could always try ask the place manager and ask him if there is anything wrong with your machine.
Hope it ind of helped!
May 30, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Why won't the water push through the coffee after using the milk frothing spout
You should get it repaired by a professional or authorized service center.
Apr 24, 2014 | DeLonghi espresso / cappuccino maker...
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Where to fine a owners manual
I own a Maxim Expres machine. I no longer use it nor have the manual, but the following are my recollections.
I have the version with an on/off switch on the front and a separate knob to control the steam nozzle.
- Use the carafe to measure the water, then pour into the tank and replace the screw-on lid.
- Measure coffee into the metal basket (don't remember the proportions of coffee to water - you
have to experiment.)
- I tamped the coffee lightly - not as much pressure as you use with a pump-driven machine.
- Put the basket into the handle, line up the slots and twist the handle to the side to secure (I'm
sure the models vary in this regard). Place the carafe under the drip hole.
- Push the button to "on". For espresso, just wait until it stops dripping. This is a steam-driven
machine - don't expect much or any crema.
- Frothing: If you are going to froth milk, you need to do it WHILE THE COFFEE IS DRIPPING.
-Wait until coffee starts dripping into the carafe (otherwise there is not enough steam pressure)
-Submerge the nozzle tip under the surface of the milk and turn the knob on the steam nozzle.
-After frothing, turn the nozzle to closed and wait for coffee to finish.
-If you wait too long to start frothing, the coffee will finish and you will lose steam pressure.
That's what I remember, hope it helps.
May 25, 2008 | Coffee Makers & Espresso Machines
Spout for frothing milk pops out
You can get the user manual on this link if you need it; Check page 6 of the download, page 12 of the manual - the spout should just pull off and push back on. If it wont, then either something needs cleaning more, something is stuck in the tube or more likely the part of the nozzle that comes off, something is broken, or you need to use a little bit more force. If it appears broken, (check in particular for a fine crack that is only visible when the nozzle is stretched i.e. when in place. This type of plastic often will close a crack enough to be near invisible when not under tension.) then you could try gluing it although i doubt if this would work. You could just put a stainless steel hose clamp around it, tighten up just enough to make the nozzle spout stay on (bit of a pain, but may work). You can contact gaggia for a replacement - in the USA; Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: e-mail: Hope this helps - if you can post back a photo or two close up of the problem area, i may have more ideas :)
Jul 05, 2007 | Gaggia Paros Espresso Machine
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
349 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
