Question about GE Spacemaker JVM1640SJ Microwave Oven
Change fuse on model#jvm1631bb002 - GE Spacemaker JVM1640SJ Microwave Oven
  • 612 Answers
Take the outer case off that reaches from one side over the top and to the other side. The fuse is located behind the control touch panel. Back where you will see wires, a capaister, transformer, ect. What your looking for is a fuse that looks just like an old round glass car fuse. It's not one though. It's a fuse made just for micro waves. Where the glass would be it's either black, white or tan. Noramlly it's a 20amp. Good luck.
Posted on Nov 19, 2009
Where is the thermal fuse located at on kenmore microwave model 665
Depending on the total part number 665xxxxxx a replaceable fuse is located behind the control panel usuallyon the floor of the control cabinet.
on one specific model "not yours" to check out the fuse locations a part number 309796 was found and I've included an image. Values of the fuses change based on specific models.
A typical location is included in the following image.
26047724-i5ybdsgcpm55v0g4hkv2rsri-5-2.jpg During previous repairs the fuse holder has failed and has required repair in addition to the fuse being replaced. This work needs to be accomplished by a qualified repair person. Even with power remove voltages remain because of stored engergy in the capacitors.
Hope this has been of help?
Jan 10, 2016 | Kenmore Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Short Circuit in changing light bulb in KHMS147SS has caused the unit to power completely down. Is there a fuse?
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 23, 2012 | Microwave Ovens
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
Microwave works normal, but will not heat food (GE Spacemaker Model JVM1631BB002)
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jj
Nov 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Model JVM1631BB002 Microwave does not heat
There is a fuse out or the heating element is bad and they can be replaced, however the price of microwaves it might just be cheaper to buy a new one. I can give you instructions and a site where you can buy it but you have to be careful when replacing them. The reason is if you do not have all the gaskets in place the microwaves could leak out and harm you. Depending on your skill level of taking things apart I could not tell you if it would be cost efficient.
Oct 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Changing a fuse
First unplug the oven from the wall outlet.
Remove the two screws in top of the grille running across the top.
Rotate the grille forward and out and remove it.
There will be a metal grate at the right. See a photo here.
Now you can access the fuse.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | GE Advantium SCA2000B Microwave Oven
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
186 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
