Question about Mitsubishi WS-55809 55" Rear Projection Television
Convergence instruction for ws55809 please mvminton@yahoo.com
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I have fixed hundreds of these sets.
They use two of the STK-392-570 CHIPS.
BEST PLACE TO BUY THE PAIR OF CHIPS IS EBAY
SEE INCOMING INFORMATION.
IF YOU LIKE IT, RATE THIS SOLUTION AS I DO THIS HERE FOR FREE.
SD TECH
Posted on Nov 19, 2009
  • Jpitt13421 Feb 16, 2011
    can you give some instructions on this please. Thanks, Jim jpitt13421@hotmail.com
I have a Mitsubishi WS-55809 projection TV. The convergence will not ajust using the user controls and the picture looks bowl shaped in every format.
you will need to install a convergence repair kit for your model. You can get the repair kit called the " WT46807, WS55807, WS65857,WS65907, WS73907 WT46809, WS55809, WS55819, WS65809 and WS65819 Convergence repair kit " which has the parts and the CD with instrucions. Its available at the following link http://tvrepairworld.com/mitsubishi_repair_kits
Feb 07, 2013 | Panasonic PT-56WXF95 56" Rear Projection...
Blinking light not turning on
Thats almost always caused by failed DM capacitors. You can get the WS55809 - WS65809 DM repair kit from www.tvrepairworld.com which has the caps and the CD with repair instructions
Sep 23, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Where are the covergence controls in ws55809 tv located
All convergence adjustments on this set are done with the original remote control--you will find the CONVERGENCE in the customer menu---if set will not adjust there you have a circuit problem.
I have fixed hundreds of these sets--if it will not adjust let me know and I can tell you what is needed to fix it.
SD TECH
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My tv has a curve at the top and the bottom? model # ws55809
Sounds like your convergence ic's need replaced. If you've never done this before then I recommend you contact a service company to look at it. Our estimate for a job like that is in the $250.00 range.
Dec 12, 2009 | Mitsubishi Televison & Video
Ws55809 tv picture bows at top and bottom. Also has shadows. Is it the bulb and where do I get one.
You have a convergence problem. The 3 picture tubes are fine. The small signal module needs reworked. The board with all the rca jacks.
Nov 29, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Convergance on mitsubishi ws55809
I can provide you with start to finish step by step instructions for this repair in this set and photos of the resistors that protect the chips and the fuses also(if one of the 2 fuses was bad the set would shut down instantly.
They are located on the middle circuit board on a large metal heat sink---That board needs to be removed from the set to replace them safely--you can see them if you remove the front speaker grill and the inspection plate behind it.
I have done hundreds of these sets.
If you want the instructions (I can also tell you a good place to buy them from) and the photos just take a minute and give me a vote here and your email.
REGARDS, SD TECH
Sep 20, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsu WS-65909 COMES ON AND TURN OFF IMMEDIATLY, ERROR CODE 2-2
Two blink code on this set means Usually one of the two pico fuses that protect the STK-393-110 CONVERGENCE IC is blown--the fuses will need to be tested and the chip and them replaced--
If you have enough skill I have step by step start to finish instructions for this repair in this set---set detects one of the voltages to the Chip is not there and shuts down instantly. I have photos of the chip, fuses and protect resistors this set uses also.
If you want the instructions for free give me a email and I will send them to you for free--if you are able to do this repair yourself you will save a lot of money--you can buy the chip on Ebay for about 14 dollars plus shipping and the same seller sells the pico fuses..............
If you want to attempt this give me a vote here--If you are not able to do it yourself I have suggestions for you about getting the set fixed--I have done hundreds of these sets!
Just reply to this post here.
Let me know what you want to do, I am here to help people
SD TECH
Sep 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi ws55809 TV
recommend you ask slinteriors http://www.fixya.com/users/slinteriors
Aug 28, 2008 | Televison & Video
Mitsubishi ws55809
Replace both convergence IC's STK392-570 located on
center circuit board on large heatsink.....................T.
Dec 01, 2007 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
195 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
