Question about Microwave Ovens
Unit fills with water, heating element works, jets dont spin at all, and dishes don't get clean. I removed the jets and tubes and also components in the unit at the bottom down to the grinding blades. I cleaned all areas but still no change. The motor also seems to be kind of loud but thats been like that for a couple years. Also how could I get a repair manual? Thank You
  • chue2u Nov 20, 2009
    Thank you for your help I plan to replace the pump assembly hopefully all will be good.
  • 612 Answers
I see that this is a dishwasher rather than a microwave. I can still help. It sounds like your pump is gone. This is why you don't have any pressure. As far as a repair manual. The best I can do without a make and complete model number is tell you to go to www.partselect.com and enter your model number. This normally will bring up a set of diagrams of your machine. If it's pretty new, it will also sometimes bring up the manual as a part number that you can buy. Also with some makes, you can go to the manufactures web site and order one from the site or by phone using your model and serial numbers. I feel sure that your pump is bad and it will need to be replaced. Good luck.
Posted on Nov 19, 2009
My plate just cracked while microwaving popcorn
Make sure you don't put any dishes in the microwave with something like popcorn because they retain more heat and have nothing to transfer the heat too. If you mean the built in spinning plate that you set stuff on and you have an older model the fan might be broken. Something similar happened to my microwave as it is pretty old i just removed the panels and cleaned everything/blew it off with an air hose and it started working again. I'd check with the manufacturers also!
Sep 25, 2012 | Panasonic NN-T694SF Microwave Oven
GETTING FILM ON DISHES, WE HAVE CHANGED NOTHING!
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 31, 2011 | Microwave Ovens
Glasses don't rinse clean in the upper rack of the dishwasher
heatman101
Aug 15, 2011 | Microwave Ovens
Not cleaning dishes on bottom even when half empty - leaving film. using rinse aid. ran two cycles with vinegar help
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 04, 2011 | Microwave Ovens
Microwave light works,timer works, tray does not spin, no power when turned on,silent
First of all it seems that the program controller unit is faulty . so check the power on this unit, check the contacts and connectors. If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
May 14, 2011 | Frigidaire FMV156DC Microwave Oven
Upper and lower spray arms are not spinning
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
May 06, 2011 | Microwave Ovens
Dosent rinse always dirt left in cups
heatman101
Apr 23, 2011 | Microwave Ovens
When attempting to use the microwave oven, the light goes on, the glass dish spins, but no heat actually is applied. What can we do to fix this or who exactly do we contact for this?
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
There is also a thermal cut off which could have tripped.
If there is heating without any issues, you can use the microwave safely
Mar 02, 2011 | Whirlpool Microwave Ovens
I have started getting a white film on all my dishes. I'm using a rinse and have since the day I bought it.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Nov 09, 2010 | Microwave Ovens
Electrolux esl 6115 dosent seem to be getting hot, filling with water but not cleaning the dishes, cleaned the filters.
heatman101
Asker
Sep 30, 2010 | Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
