Question about Dynex DX-L42-10A 42 in. LCD TV
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
  • 11,361 Answers
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Posted on Nov 19, 2009
  • Angie Osborne
    Angie Osborne Nov 19, 2016
    Thanks u make it sound easy lol. Everyone thought j had it on
    Mute. And it did make a noise before it went out but nobody else heard it but .me. thanks for taking time out fore
How do I connect wireless headphones to a Dynex 42"TV model DX-42E250A12?
Check this link for a user manual
http://www.dynexproducts.com/cms/documents/Manuals/DX-42E250A12_11-0618_MAN_V1_EN_Final%20lr.pdf
Sep 07, 2014 | Dynex Televison & Video
No sound - Dynex DX-L42-10A
No, I have not heard of this either. If you've checked your connections, etc and still have no sound, try to do a power cycle of the TV. Turn it off, unplug it and leave it unplugged for a few minutes. Plug it back in, turn it on and restore settings to factory defaults. If you still experience issues, then you'll want to proceed with service repairs. However, depending on the repairs necessary, it may be cheaper to pursue replacement, than get it repaired.
Jan 21, 2014 | Dynex DX-L42-10A 42 in. LCD TV
Dynex 24" lcd led tv
Check to see if mute is on, and through the menu to see is sap is on. Sometimes button are accidentaly pressed. If none of the above, the ntry replaceing your main board.
May 05, 2011 | Dynex DX-LCD37 TV
I'm connecting my tv to a stereo receiver to get stero sound through the stereo speakers.done this a hundred times with other tv's but can't get this one to work.
how do i hook up my stero to my dynex tv? stero has no hdmi cabl neither does my cd player. i also go through my cable box not high def Thank u for any help
Jan 02, 2011 | Dynex DX-L32-10A 32" LCD HDTV
Headphones on my dynex 42-inch tv the speakers are still on
Use the MUTE button on the remote to mute your TV speakers and then you can still use our headphones. You can continue to adjust volume with the remote and it will only affect your headphones. You may need to do this each time you turn on the TV and use headphones, but that is a small annoyance.
Dec 26, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
How do you shut off the internal speakers in Dynex 42" LCD tv?
The best solution i have found so far is to hit the mute button on the remote. It will display a small "MUTE" box in the lower left corner of the screen for a short while, but that will disappear. Another issue that makes this solution less than perfect is that you must hit the mute button every time you turn on the TV. There's got to be a better way, but I just can't find it.
Dec 25, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Picture but no sound
First re-check your wire hook up and audio menu settings. If its under warranty then get it replaced if not the repair is an easy fix. Should be sameday return @ your local tv repair center.
Jun 13, 2009 | Televison & Video
VIEWSONIC VPW425 42' PLASMA SOUND FADES ALL THE WAY OFF
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Stereo/mono on iLo 42 screen tv
I have encountered the same problem. I have looked through the menu at least a hundred times to find an answer, but the only thing that I have been able to come up with is to push the MTS button on the remote.
Mar 12, 2007 | iLO 2600 Television
Dynex DX-L42-10A 42 in. LCD TV Logo
574 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
