Question about Acer Aspire 3000 Notebook
My acer Aspire 3000 with a fresh windows xp home install, is having issues with the touchpad pointing device. I plug in a wired USB mouse and have no issues, but with the touch pad i am getting very eratic responses from any movement, The keyboard is also acting quite odd. Occasionally they both work correctly. I have no idea where to go for help.
  • 446 Answers
You may need to reinstall the drivers for keyboard and touch pad, if you still have the drivers cd on hand look for these two important drivers, since you have the new xp installed all drivers have been erased.
hope this helps
Posted on Nov 19, 2009
Testimonial: "I did reinstall both drivers, it is still working sporatically"
Touchpad, mouse and keyboard not working
Try installing the touchpad driver from here http://www.helpjet.net/files-Acer-Aspire-4810T.html#ATouchpad
Once you are done restart your Acer and see what happens.
If this doesnt resolve the issue it may be a problem with the hardware in which case you may need a new touchpad. otherwise just use a mouse as a fix either temporarily or if it turns out to be to expensive to fix.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Touchpad nor external mouse will work on my acer aspire 1640z
control panel > device manager > scroll down to mice and pointing devices > if touchpad is listed (may be symantic or alps} highlight and click uninstall. Reboot the laptop, windows will be forced to reload the drivers when it recognizes the device. It may ask you if it can search windows update for a fresh driver, allow it to complete the install. reboot
Sep 30, 2009 | Acer Aspire 1640Z Notebook
Acer aspire 3000
The bootable XP cd you have will work - You need to first reinstall the Operating System(XP), then download and install drivers for the devices(Such as touchpad, wireless, etc.)
The device drivers are all available from Acer's support site; If the Network Card driver isn't installed after the windows XP installation, you will need to use a different computer to download the drivers, and transfer them to your laptop using some sort of removable media - USB Flash drive, portable hard drive, memory card, etc.
Feb 13, 2009 | Acer Aspire 3000 Notebook
Touchpad on acer aspire 5100 series is locked
plug in a usb mouse, go to control panel>system>harware>device manager and click on the + sign next to pointing devices. Right click the touchpad and click on uninstall. Reboot the laptop and unplug the usb mouse. This should pick up the touchpad as new hardware and reinstall it. Hopefully this will resolve the problem.
Dec 29, 2008 | Acer Aspire 5100 Notebook
Cursor is frozen and can;t move on my laptop
Plug in a USB mouse, and go to Contol Panel>system>device manager and click on the +sign next to pointing devices. Right click touchpad and uninstall the touchpad, then reboot the computer, remove the usb mouse. Windows will pick up the touchpad as new hardware and re-install the drivers for it etc..
I hope this helps
Dec 05, 2008 | Acer Aspire 5315 Notebook
Aspire 5101wlmi
If you have got a usb mouse plug it into your computer then go to control panel>system>hardware>device manager and go to pointing devices. Right click on the + sign next to keyboard and touchpad, click on uninstall. Then reboot your machine, take the usb mouse out. Windows will reload the correct drivers for the keyboard and touchpad as new hardware and your problem should be resolved.
I hope this helps
Nov 12, 2008 | Acer Aspire 5101WLMi Notebook
How to disable mousepad?
normally the Fn and F7 key, it's the key with a finger on a square icon, or right click on the touchpad icon in taskbar>pointing device properties and select device settings and then dissable.
Sep 14, 2008 | Acer Aspire 3000 Notebook
Mouse touchpad, keyboard, and usb drives will not work
One thing you can try (for the touchpad)
Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
Hope that helps for your touchpad
May 05, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
