Question about Kicker CVR12 Car Subwoofer
How much resin and hardener should i mix up, i'm building a fairly big subwoofer enclosure and i'm not sure how big of a batch to make....... this is my first fiber glass enclosure, but i want to get it right..... and also, how much resin hardener and matte am i gonna need for like 8-10 layers, cause its gonna have like 3500 watts bumpin in it.... i bought 1 gallon but i don't know how much i will need, and please any other advice would be greatly appriciated.... the temperature is about 70 in the day and 45-50 at night.. if someone could let me know what to expect.......
  • 4 Answers
Fist you need to find out how much air space you need for each speaker thats going in the box then you will need a frame something light but durable you can get sound board from lowes thats wat you need to start with and when your mixing your hardener and fiber glass mix only a small amount at a time just a little hardener add to much and it will dry immediatly if you mix a lot of it at once you will waste most of it do it during the day it needs to be around 60 degrees to get it right
Posted on Nov 21, 2009
Epoxy floor is not drying in some places it has been a few days still has a few spots not drying Paint was mixed well what can I do?
although its not widely known , but two part epoxy paints have a resting period they need to have after there mixed vigorsly together , the label should denote how long this time should be , its usually about five minutes or so , this rest is nessacary for the two chemicals to adsorb into one another (prevents bubbles too), floors that don't harden , well theres one sure fire way to fix em , use solvent and remove non hardened paint with old rags (lots of em) but sometimes if only slightly sticky then you can go over them with a fresh batch (using proper mixing methods ) the new paint will encapsulate the old paint and harden over it
Sep 16, 2015 | In Microwave Ovens
Bubbles after 24 hour cure
I recently covered a wooden chair in epoxy resin. It is the nature of the product to create bubbles as it hardens. The directions stated to gently blow on the bubbles as they formed. Check it often and blow on any bubbles that form in the first 45 minutes after application. This worked quite well for me. Be sure to wipe up any drips in that first 45 minutes too, they are a pain to sand when they are dry!
Mar 19, 2014 | 3M Scotch-Weld Epoxy Adhesive DP125 Plus...
Royal Albert China Teapot has a small piece broken at top where lid fits. I have the pieces. it is at the back of teapot near the handle Measures abt. 2mm x 2mm. There are three pieces and some slivers . I...
Get some araldite (epoxy resin) mix equal quantities of the resin and the hardener and somehow glue it together. This stuff is strong once dried and is heat resistant and as far as I know...non-toxic once dried.
It will be a bit fiddly though, and you should use a little hand held clamp to keep the pieces together as tightly as possible until it hardens.
Sep 16, 2009 | Computers & Internet
What is the cubic feet of air space
it's a measurement used to describe the empty air inside an enclosure. When you build a speaker enclosure, such as for two subs, u build it to fit the componets air space recomendations. keep in mind anything inside the enclosure like braces or the magnet part of the speaker will deduct from the measurment.
Sep 15, 2009 | Mmats Pro 12 Car Subwoofer
How to repair tent trailer roof
Go to an auto parts store and buy a fiberglass kit. Resin, hardener and cloth. Clean and rough the area. apply a coating of mixed resin, then a layer of cloth. Let it dry and repeat a couple of times. After you are satisfied with that get a gallon of Elastomeric, you will find it at Lowes/Home depot. Clean the entire top and apply 2 coats with a brush or roller about 24 hours apart. No rain or moisture for a couple of days. Project complete, water proof roof.
Mar 25, 2009 | Sport & Outdoor - Others
1998 ZX9R C1: Fairing damage. What do I fix it with?
ello mate,, well theres some basturds about ay,, this happened to me once,, any way,, to bond a crack or build up a hole, turn the fairing round so u r lookin at the back of it, rough the crack or hole up with some sand paper,, then get your self some fibre glass matting wad,,and some resin, and hardener, using scissors cut the matting out to shape mix up some resin and apply to the back of the fairing,, this is messy stuff ,,but will bond it well,,then turn it over ,,if u still have a visible crack and want to repair that,, then run a grinder down the crack ,,so it widens the crack just a bit ,,and fill it with isopon filler,, just the normal kind of filler, for dents etc,,
Mar 24, 2009 | 1998 kawasaki ZX-9R Ninja
I've been told by a plumber that the tubing to the jet is leaking
You could try Plumber's epoxy stick or paste if the leak is not to big!
The stick has the resin & hardener already in it. The paste you would have to mix equal amount together. I would recommend the paste because it would probably stick to the surface better for you application! Available at Lowes.
Jan 27, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Car dashboard
yes but mostly it needs to be done by dash tech recommended or apolstry shop <<< spell check
but here are the steps
remove dash place out of sun
mix batch of heat resistant resin
apply resin to dash the whole dash make a little thicker on dash
let dry
now when dried and hardened after 24 to 48 hours you take a sanding block and sand down smooth with sand paper then repaint with color dash that was before
you can use this same resin to also fill in the cracks of dash but you will still have to sand and repaint the area you just applied the heat resistant resin too this is called touch up the dash
dont use a power sander on this type of project you could damage your dash permanently
Jun 11, 2008 | 2007 Hyundai Accent GS Hatchback
Subwoofer Box for four lanzar 15"
what r u trying to do ?shake the car apart?Only kidding that a good questin 4 15: woofers in 1 enclosure>?what kind of enclosure ?how much space r we working with ? i use to be a installer , i also built costume boxes.I need to knoew how much space u have is it a car van,pick-up?I think an iso baric enclosure woukld be your best bet, it would take up the laest space. What frequency are you going to be runnig to your subs? what do you want? punchy bass,over the big tom drops?
what amp r you running or should i say amps?
you'll get the highest spl in a sealed enclosure,but i dont think thats what your looking for.you want heavy vibrating soud,am i correct? a band pass box will give that to you in a close space.bass sounds better and louder the further away you get../.give me more info then ill give you a layout.but 4 now this might help or solve your problem
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
they have all the wiring and p[hyschics and designs of boxes. rating please.
Jan 25, 2008 | Lanzar OPTI1222D Car Subwoofer
Kicker CVR12 Car Subwoofer Logo
322 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
