I have a canon IR330 and it consistently misprints a horizontal (for regular 8.5x11 paper) swath about three inches wide. The quick fix for this is if I shake the toner canister (beside the drum) then it subsides for about 100 pages, but then it gradually (within 10 pages or so) goes from faint to not at all along that swath. The drum is almost new and there is no visible damage. As I run a publishing business, I cannot have my machine malfunctioning every 100 pages. Thanks,
  • 1,113 Answers
Hi, I'm thinking you toner is low, and shaking it is just scraping the edges, I suggest replacing toner, are you using genuine toner?
The other things that cause faintness would not go away via a toner shake with the only possibility's that I can imagine, beside incorrect, non makers or low toner is the developer unit not turning correctly or something a miss with the toner hopper, another thing you could try is to cleaan or replace the primary charge roller....but before I go any deeper, please confirm you have tried another "Canon" toner and have the same result.
Cheers from Oz
Steve
Posted on Nov 19, 2009
Ir 33o double side printing problem
Depending where the paper is getting jammed at, take of all rubber pads off the right door. Several places like on each side of the guides. I can think of six pads that need to be removed. They are black and about 1/4 inch wide. Sometime they get sticky and cause the guides in the duplex area to not function correctly.
Sep 01, 2014 | Canon iR330-400 PS Ver 1.0
Canon MP500 printing blank lines
I found an article with steps you can take to troubleshoot printer issues:
http://www.castleink.com/category/288/Fix-gaps-in-printout-horizontal-and-vertical-lines-Video.html
Still, have issues with your printer call me out at 1800-204-4427. I can solve you out via phone.
Aug 24, 2017 | Canon Office Equipment & Supplies
Service manual canon ir330-400
hello friend, you can find the canon iR330 iR400 service manual in below link:
Canon iR330/400 service manual:
http://goo.gl/WTxUnt
thanks
Aug 05, 2013 | Canon imageRUNNER 400S Copier
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
I have a canon 4570 imagerunner,the problem i am facing is when i am printing a copy 2(sometimes 3) horizontal lines appears on the print.please sugest. Thank You
If the lines repeat in a regular fashion, with a consistent distance from each other, you need to replace the imaging drum. I would take a print out with the horizontal lines on it, then fold the paper up until two of the lines overlap each other; this will tell you the general diameter of the drum and give you an idea of what to look for inside the machine.
-David.
Nov 03, 2010 | Canon imageRUNNER 4570 Copier
Copy is smearing from top to bottom on left side of paper about 1 inch wide.
The print in the smudged area, does it wipe off the page like not fused well to the paper. Do you also have a crinkling noise, if so the sleeve in the fixing assembly has torn. You may still have it under warranty with canon and can get it fixed for free.
Good luck
Bob
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
21 people viewed this question
jasbo
jasbo
